POD-Kelvinator
Interesting too because the ad says "Not hot water system required" did it have a built in heater? Terry
No heater required.
This may mean that it had a suds save cycle. Not only could the suds save cycle be used to reuse wash water but in the fifties and sixties most Australian laundries were lean to's onthe back of the house. So if hot water was unavailable you could heat it in the copper and use the suds save cycle to fill with hot water then carry on with the rest of the cycle automatically.
Leon, I think in a Choice reliability survey in the late 70's only two percent of respondants owned a Kelvinator. So there was not many out there to start with. Shame.
Harry thanks so much for the information. I didn't think it could have had a built in heater. Terry
Built in Heather
Hi Terry,
Most machines in Australia up until the late 70's either had a heater or it was available as an option. (2400W element)
It would take about 90-120 minutes to heat the water from cold to 150degF
I've been curious about how the rest of the solid tub machines heated. (Obviously there is nowhere to put the element) One of my machines, (Simpson) fills into the outer tub, heats and then pumps the water into the wash bowl. The other machine, (Fridgidaire) you fill the inner tub, clip the suds save ball over the end of the drain hose. Spin the water into the outer tub and then heat. To wash, you open the ball on the end of the drain, start pulsating and the water refills via the drain hose.
The Kelvinator would've been a solid tub machine, so it would be interesting to see if it has the same complicated system that the Simpson does.
The advantage of the heater with a perferated tub, was that you got a long progressive heated soak before the wash started. With the solid tubs, the clothes stayed dry until the water was hot.
Thanks for the information Nathan! Do your top loaders being made today still have heater built in?
