Portable GE disposall disposer
combo52
Apr 4, 2008
17,536
50 Year Repair Tech Beltsville,Md
Anybody ever see one of these
I remember seeing one for sale in the store back in the early 60s never seen one since picked one up today while helping a friend, clean out an estate of an appliance collector.
Uses the same basic grinding design as GE's built-in units around the same time, pretty cool you just set it in the sink fill it with your waist, but it's reasonably full twist the motor on the top run water on them corner of the unit. It runs into the grind chamber right through it. It drains out the bottom and right down your drain.
Seems to be very heavily built and well designed.
I have one. I only tried out the motor on it; never actually used it. I really do have to make a point of trying it one of these days.
Hmmm
I imagine it would be a good tool for us composters.
I was cautioned not to install a disposer in my house because of our already challenged septic systems in our village that is built on lots of ledge. The septic engineer explained that new disposers actually do too good a job of grinding up the food waste so instead of decomposing in the tank, it goes right into the leaching fields where it builds up and clogs the works. I still want a Disposall but...
"You could run the portable disposal in the garden...
That's what I plan to do.
Contrary to our idiotic local codes, I plan on diverting  my "gray water" into a cistern for watering the land. There are a lot of people in my area who have made similar changes to their plumbing to conserve water and to limit what goes into the septic system.
I think it was in 2000 when we had a severe drought. I had some young trees that I watered with rinse water from the top loaders I was using then. I drained the machines into a 30 gallon container with a submersible pump with a male hose adapter on the outlet and I sent the water outside through the garden hose that went through an unused dryer vent. The water did not hurt the trees. At the same time, I reused the wash water twice by draining the wash water into adjoining machines.
This is one piece of equipment I would love to get my hands on. Maybe one day. I was fortunate enough to find an 8000 RPM GE in the scrap yard of all places so I picked it up and since it spun freely. I paid $2 for it and it works. It just needs a flange and then I want to try grinding stuff with it.
