brisnat81
I do a lot of bulk cooking, IE 4-5 Gallons at a time.
Depending on what I'm doing, the pot might be half full of of a solid, that I'm then cooking down.
I can see that putting the pot on the stove, putting the solids in and then the water would be easier than lifting 40lbs onto the stove stop.
Then once the cooking was finished, Scoop the solids and you're left with half to two thirds of the weight in the pan. Same if you're stove top canning, put the Jars in, pour the water on, process and then remove the Jars when cold, you're only shifting half the weight rather than the whole thing.
I have no issue lifting the 40lbs onto the stove, but someone smaller would really struggle. Thats the type of scenario I can see this working. Unless you cook in bulk however it would seem to be an unnecessary novelty.
