A couple of interesting notes:
Yesterday I worked on a 1979 Kenmore electronic belt-drive machine which I had sold a co-worker in 1995. They've used it for almost 14 years, and my co-worker insists that his wife wash in cold water. They have had two kids during this time, so the machine has seen a lot of use, and to my knowledge they have always used a liguid detergent, such as Era, Wisk, and All Free and Clear.
One of the machine's problems was a locked-up pump. I had replaced the original pump in 1995 with a brand new FSP (Whirlpool) pump and was surprised that it would do that. Most of the locked pumps I've seen have been aftermarket. There was also about 1/2 pound, yes 1/2 pound, of thick, gray, slimey goo on the bottom of the tub. If was rather gross actually.
I have read that washing in cold water (someone mentioned that above) doesn't flush certain oils from laundry down the drain, AND that liquid detergents can leave a filmy residue, which powdered detergents will eventually remove. It took about 30 or 40 sheets of paper towel to wipe out the muck, which had a musty, unpleasant odor. I have read on other internet sites where this is even more common on newer machines which have plastic outer and/or inner tubs (easier for the scum to adhere to).
I also heard a long time ago that liquid detergents from the 90s had a lot of alcohol in them, which would dry out rubber components. I didn't notice any apparent deterioration of any of the rubber parts in the tub, in fact they looked great, almost as if the goo had protected them. Today's liquids, being used in lesser amounts, would have less alcohol, if they have any at all anymore. My only concern would be where that scum came from, and I blame cold water washing more than anything else for that.
Gordon
