ptcruiser51
Never seen this addressed here. If you do a lot of pre-treating for a load, should you adjust the amount of detergent?
Sometimes my shirts from THD duty need a lot of attention. As do clothing/bedding that have experienced the heartbreak of psoriasis.
Is regular dosing overkill or waste? Rinsing issues? I always try to go for a 2nd rinse if I can. The Maytag TL's in my laundryroom give a semblance of a 2nd rinse if set on PermPress cycle.
I've tried pre-treating with just detergent I'm using in the cycle (Oxydol). Disappointing results. Usually I use Shout Gel or FelsNaptha soap for stubborn stuff.
