Pressure Cookers
xraytech
Feb 11, 2009
2,166
Rural southwest Pennsylvania
I have some questions regarding pressure cookers.
About 9 years ago for Christmas I received a Cooks Essentials electric pressure cooker. I have never really used it much, however I'm now very interested in canning chicken and beef.
My questions are: is my electric pressure cooker suitable for canning?
If not may I get suggestions on what brands of stovetop pressure cookers are recommended. I'm thinking I'd want an 8 qt model. I'm also very unsure of using a stovetop model. I'd assume it's easier to regulate on my sensi-temp burner.
Any tips and info are greatly appreciated.
I don't know about canning, but I think with a stove top pressure cooker you have way more control of the heat settings than with an electric pressure cooker. The Cooks Country television show just discussed pressure cookers this morning. They much preferred the stove top models over the electric models because of this.
For all canning
You use 5 or 10 pounds of pressure, most low acid veggies are canned at 10 pounds, I use 5 pounds for high acid stuff like tomatoes, if the pressure can be regulated to 5 or 10 pounds an electric cooker would be fine, Flex Seal made a large electric canner in the late 40s.
Not for all canning
The Kansas Extension office recommends 15 lbs for green beans and most low acid foods.
Meats are recommended to can at at least 240 degrees, or 15 lbs.  Most small electric pressure cookers can't reach that pressure.
My Mother has always used Mirro Pressure cookers.  The Jiggle weight is easy to use, and parts are always available.
I would recommend contacting your local Agriculture/Extension agent to verify what is recommended in your area.
I have
Never heard of 15 pounds for any canning,,,Donalds Mother cans everything by hot water bath, as everyone used to do,I don't believe its dangerous, but im sure not going to boil a big pot of water for 3 hours!! I can do 2 or 3 canners full of beans in the time it takes her to do 1.I do my green beans for 25 minutes at 10 pounds which is what the Presto book says to do.
Maybe you live at a lower elevation
Hence the advice to check with local AG agency.  The phone call is easier to make before you get botulism.
Botulinum spores are very hard to destroy at boiling-water temperatures; the higher the canner temperature, the more easily they are destroyed. Therefore, all low-acid foods should be
sterilized at temperatures of 240° to 250°F, attainable with pressure canners operated at 10
to 15 PSIG. PSIG means pounds per square inch of pressure as measured by gauge. The more
familiar “PSI” designation is used hereafter in this publication. At temperatures of 240° to
250°F, the time needed to destroy bacteria in low-acid canned food ranges from 20 to 100
minutes. The exact time depends on the kind of food being canned, the way it is packed into
jars, and the size of jars. The time needed to safely process low-acid foods in a boiling-water
canner ranges from 7 to 11 hours; the time needed to process acid foods in boiling water
varies from 5 to 85 minutes.
Adjustments for Pressure Canner
Altitude in Feet Dial Gauge Canner Weighted Gauge
Canner 0-1000 1<span style="font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 11px;">1 10</span>
1001-2000 11 15
2001-4000 12 15
4001-6000 13 15
6001-8000 14 15
8000-10,000 15 15
[this post was last edited: 9/7/2015-01:58]
my mother & grandmother
have always canned green beans at 10 pounds for 20 minutes, that's what her mirro-matic recommended way back when.  I bought myself an All American canner when I got my house and did the gardening thing...it doesn't have a rubber gasket to fool with.  I later gave it to my mother and she's still using it almost 20 years later with no problems.  It uses the round triple weight jiggler like a mirromatic does.
The "way back when" is the problem here...for instance, the newest Ball Blue Book (which is authoritative...may even be a republishing of USDA guides) now has you spike tomatoes with lemon juice to get the acid levels up...the newest varieties are lower in acid than heirloom varieties. Moral of the story...don't rely on "momma's history recipes" for canning---get the current information.
Last time I canned tomatoes I did the lemon juice thing...they tasted like fresh tomatoes when they were later eaten! Just looked at the Ball Blue Book online and it's still 20 minutes at 10 pounds pressure for pints of green beans and 25 minutes for quarts, so Mother is still doing it right. Green beans are about all we can anymore, she freezes most other vegetables. We just don't really like the taste of frozen green beans so we just pressure can them. After each batch comes out of the canner, we count the "pops" as each jar seals...if one doesn't seal for whatever reason, it will be cooked for dinner the next day.
Since the question was about canning meats, I checked several sources including the blue ball book and the instructions with my canners. Meats are canned at 10 pounds. Adjustments have to be made for higher altitudes. Unless the directions for your electric pressure cooker specify how you do exhausting of the air in the jars, it probably should not be used for canning. My Presto canner calls for exhausting steam for 10 or 15 minutes before putting the weight on the vent pipe.
Ground beef should be browned before canning. I was surprised to read about forming the meat into patties before browning then using wide mouth quart Mason jars in which to stack them before processing. I have canned Sloppy Joe stuff successfully at 10 lbs, but that is acidic with the tomato sauce. The Heat Minder set at 250F holds 10 lbs in a canner.
One of my grandmothers canned meat and I have to tell you you have to do something with it to make it look appetizing. It is fine if you want to turn chicken into pot pie, chicken & dumplings or chicken salad, but to just heat it up out of the jar and plan to serve it does not make for a great presentation.
I still believe
Food spoilage depends on cleanliness of preparation, for instance, when I fix green beans, I wash them thru 7 sinksfull of water after stringing and breaking, I run my jars thru the dishwasher, and boil the lids, then I bring the beans to a boil before packing in the jars with a tsp of salt, then I exhaust the canner for 7 minutes, then process, Truthfully, I have eaten beans canned by hot water bath method all my life, All my Aunts on Dads side did it that way, and have never heard of anyone getting sick, my maternal Grandmother used a Presto beginning in 54 and that's how I learned to use a pressure canner, the main reason I use it is not because im afraid of the water bath method, but because its so much more convienent, Most people around here can tomatoes by simply cooking them and putting then in the jars then sealing them, no other processing, I do mine like Martha Stewart because they are just plain better, I pack then raw into my jars then process in the canner at 5 pounds..they come out like fresh .
My Grandmother
Always canned her meats in the oven.  She would link the sausage, or chunk the meat then she would brown the links, she would then pack in the jars and cover with grease.  She would place the packed jars in a roasting pan and fill the pan with hot water, then placed them in the oven of her woodstove.
Something tells me that the USDA wouldn't recommend that method any longer.
Cleanliness during preparation is important, but botulism is a very hardy anaerobic bacteria.  Processing at 10lbs is not unsafe,if you are reaching the target temp,  but what is it hurting at 15lbs besides possibly overprocessing a little bit?  I don't think it would be as over processed as boiling in a water bath for 11 hours or so. You do need to adjust for altitude.   Ball no longer recommends that you boil the lids prior to processing in the pressure cooker.
Once you un-jar your food, did you mother tell you to boil it at least 20 minutes before serving?  Mine always did.
[this post was last edited: 9/7/2015-15:26]
I really admire you people that can your own foods, both in and out of a pressure cooker. It's a lot of work but when you're finished you have something you can be very proud of. Back in the SF Bay Area there were always tons of fresh fruits and vegetables available for canning. You could grow a lot of things at home.
Here in the Desert it's a different story. Dates, table grapes and cantaloupe are about the only things grown locally. Who cans dates? Things like tomato plants, which normally like heat, are barbequed in the desert sun. This thread reminded me that I have a large Mirro canning pressure cooker in the closet that was a gift. I'll probably never use it. As far as regular pressure cooking, the electric unit beats the manual one hands down.
I've never actually canned anything myself, but when I was a kid I was around it every Summer. My paternal Grandmother canned just about everything, She and Grandpa owned a full city lot next to their home in Richmond, Calif. Grandpa planted the entire lot in vegetables and he grew everything. Grandma owned a dry cleaners in El Cerrito, Calif, that she worked in everyday taking in the dry cleaning and doing alterations. Then during the summer every night after dinner she would can Grandpa's vegetables in her 2 large canners, I believe one was a Mirro and the other either a Wearever or Presto. I think that they each held 8 quart Mason jars at a time. Those canners would be singing away on her OKeffe and Merritt gas stove until at least 10 pm. She canned green beans, tomatoes, corn, beets, sauerkraut, mincemeat, rhubarb, peaches, pears, you name it Grandma canned it. Of course she also made her own jams and jelly, and they were so good! Every night at dinner they would be on the table to go with her homemade biscuits. They had a big basement and the canned jars were lined up like soilders down there. And I do recall that she used to say that you needed to boil or at least heat home canned green beans for 20 mins. to be sure that any possible botulism was killed. The summer my Dad died my Mom tried to can tuna because she used to serve us tuna sandwiches all the time and she thought this would be a good way to economize, since she saw that she could buy a whole Albacore tuna for $5.00. Well she spent a whole day canning that tuna and got I believe 6 pints. The tuna was delicious, but that was Moms last foray into canning! Too much work for her, and I don't blame her.
Eddie
Re Heating canned food....
I discovered if you heat your canned food in a pressure cooker to 15 pounds then serve it ,it improves the taste ..Sometimes beans can have a "canned" taste.
Hans, it is a safety thing. The food needs to be boiled for 10 minutes in an oxygen atmosphere to destroy any potential botulin toxin. Since the air is exhausted from a pressure cooker at the start of cooking and the food surrounded by steam, it would not get the benefit of the exposure to oxygen if reheated that way.
So, here is a related question regarding pressure cookers.
Does the internal temperature of a pressure cooker vary with changes in altitude? If it does vary, does it vary to the same degree as atmospheric boiling is effected??
I'd assume considering the physics of a weight/gravity/oriface regulator that the internal pressure (temp) is pretty much fixed with changes in altitude. Pressure is set based on the area of the oriface and the weight attempting to seal it. I suppose there could be a tiny variance due to the pressure against the weight from the outside air pressure.
A Bourdon tube pressure guage will read increased pressure at higher elevations since it's reading is relative to the outside pressure.
Just a curious pondering.
Yes
Water boils at a lower temperature at higher altitudes, thus the need to increase the pressure in the vessel in order to increase the boiling temperature.
..."As atmospheric pressure decreases, water boils at lower temperatures. At
sea level, water boils at 212 °F. With each 500-feet increase in elevation, the
boiling point of water is lowered by just under 1 °F. At 7,500 feet, for example,
water boils at about 198 °F. Because water boils at a lower temperature at
higher elevations, foods that are prepared by boiling or simmering will cook at
a lower temperature, and it will take longer to cook."
. . ."Even at sea level, meat and poultry (as well as low-acid vegetables and
fish) must be processed using a steam pressure canner. If using a dial
gauge at high altitudes, the pressure in the canner must be increased
by 1 pound of pressure for each 2,000 feet above sea level. If using
a weighted gauge, the 15 pound weight must be used at all altitudes
above 1,000 feet. You do not need to add additional processing time if
the pressure of the canner is adequately adjusted."
"All home-canned foods should be canned according to USDA or USDAendorsed
recommendations. Low-acid and tomato foods not canned
using these methods present a risk of botulism. If there is a possibility
that any deviation from the USDA-endorsed methods occurred, boil
low-acid and tomato foods in a saucepan before consuming to prevent
the risk of botulism. At altitudes below 1,000 feet, boil foods for 10
minutes. Add an additional minute of boiling time for each additional
1,000 feet elevation (for example, at 3,000 feet, boil for 12 minutes).
Spinach and corn should be boiled for 20 minutes at all altitudes. This
is due to the high density of these vegetables."
There is a chart in the publication I listed.
In Wichita where I live we are 1,299 feet above sea level. We are supposed to, and I do, use the 15lb weight.
Hans--Mocksville has an elevation of 889 feet, so you are good at 10 lbs. [this post was last edited: 9/8/2015-09:07]
