Just hosing down the front of the condenser coils may not totally do the trick. Both front and back need to be done to make sure the condenser has optimal air flow.
Just cleaned the rear of my AC's condenser coils, caked with several years of pet hair, muck, dead insects and god only knows what else. Stuff was so thick in places thought it was a type of foam insulation. Used plain ole Lysol kitchen and bath cleaner, lots of warm water and a scrub brush. Several rinses produced the most ghastly black water and "lint".
Unit that before was cycling off every 10 or so minutes due to condenser over heating (so said the AC repairman), has been on now for over one half hour and the AC is streaming ice cold air. How cold? Incoming air near the register is about 82F, out going from the top of the AC is about 57F.
While you have the AC out and cleaning, it is a good time to see if the fan motor is one that requires oiling. My Friedrich fan motor takes 20 drops per port of SAE20 oil, once a year (according to the directions on the motor's plate). One was supposed to oil the motor every month during the first year of operation, but cannot imagine anyone pulling a behemoth like a Friedrich "WallMaster" out of the wall, and taking it apart every thirty days to get at the motor.
L.
