Most any of the better electric ranges that supplied top heat during baking baked well and evenly. The Ropers and early 70s WP ovens did not use top heat during baking and therefore did not bake biscuits as well. The WP I had in an apartment had to be left on the Preheat setting during the 10 minutes of baking to decently brown the tops of biscuits. The preheat setting used both the bake and broil elements at full wattage.
Where Frigidaire ovens are real powerhouses is in their broiling. Each oven in my 61 has a 3700 watt broiler element and the other night when I broiled burgers in the short oven, I noticed pops being converted into flashes of flame. Among the ranges I have used, I have only seen that in Frigidaire ranges with sealed Radiantube broiling elements. The open coil broilers in my 54 Frigidaire are very fast and even also.
I remember users of gas ovens having to give cakes and pies a quarter turn once or twice during the baking process because of uneven flame making one side of the oven hotter. Then gas stoves got cheap and instead of using the heavy cast iron or steel plate above the burner, they used a thinner piece of steel that could warp and provide uneven heat distribution to the oven cavity which resulted in uneven baking. My mother's Crown had a heavy plate and a few minutes into the preheat there would be this big DUNG sound when the plate expanded. The thermal inertia of the plate often resulted in a piddle of water on the kitchen floor at the front corner of the stove where water vapor in the gas drained after condensing on that slab of metal in the early stages of preheating.
