Oh, wait... that's the truth!
Louis, as I grew up with EuroFL, I thik to be able to say something about them...
1. Whirlpool brand, started to be sold "near" Philips brand and THE TRUTH is like MrX said.
Then MERLONI'S APPLIANCES ARE NOT WHIRLPOOL'S! Merloni's got only Ariston and Indesit brand which they sold with.
2. I think to have the "key" about second button: as someone's said the second button might mean permanent-press...it's quite like the solution (I think)...
Here we call it "ANTIPIEGA", and that's the function of it: IT LEAVES THE WATER IN AFTER THE LAST RINSE, TO AVOID WRINKLES. That will be true if that function there's not in the spin regulation, like somtime happens.
In some cases this function is incorporated in the timer, as well as you select the delicates cycle and it stops with water in after the last rinse, so you can choice to go ahead with the spin or make the drain only.
Either my 1981 FL Sangiorgio has got it! The function is the same in the delicates cycle, while if you press that button with the "1" cycle, the cotton-45°C-pre-wash, the machine stops after the soaking (differetly, if you don't press it, after "1" cycle, the machine does AUTOMATICALLY the "2" cycle wich is generally whitest-white-cottons-90/70°C as you selected)
That's all. I tried to found that machine on my Philips-Whirlpool brochures collection, but I didn't find anything, although thath I'm quite sure that what I said it's true.
GoodBye everyone
