here's my game plan
gonna run it everyday for a week or so and hope any and all oil left in the spin shaft will work it's way out. i agree i think someone did oil it because it is noisy and i think they were trying to quiet it as saltysam said above. i know i didn't oil it when i got it.
then i will pull clutch out again and repeat the cleaning process. i see now i can pull it from the bottom so i won't have to pull tub out again and flip machine. all i have to do is disconect agitate shaft from the arm coupler which will be easy. the clutch will then drop right out when i remove center hub nut.
i also possibly know of a source for a clutch, i am going to call about it tomorrow. but i don't want to put another good clutch in and have it ruined by falling oil! that's why i want to run it everyday for awhile.
i also started looking on the web for a place to buy a sheet of clutch lining material that i could cut with a dremel and make new clutch linings.
and if worse comes to worse i can always freeze it up somehow turning it into an impact syle like joel described above and add a capacitor to the motor start winding like my 2 1965 machines have. then when it starts spinning the motor will come up to speed as the tub does like my other two. i prefer not to go this route as i agree it's gotta be hard on the motor and rollers. hopefully cleaning it again will do the trick.
as far as the brake working i don't care anymore about that!
that's thre least of my worries right now concerning this machine. it can just coast to a stop like my other 2 do.
i could pull transmission again and remove spin shaft but that's a big overhaul that i hope to avoid also! i'm just hoping any oil left will drip down into clutch now and be done with it! we will see and i will post pics as i continue.
i'm not giving up, it may take me all summer but it will run properly!
i did get the 65 turquoise custom imperial water tested tonite and it is going great! but i do have a concern about it too. it has the impact syle clutch but sometimes when i start it on spin it acts like an impact clutch should, motor slowly coming up to speed as tub does, other times motor starts instantly and tub gradually works itself up to full speed including repidry 1000? have no idea what this is all about?
