When both my washers (a TL and a FL) drain at the same time, water comes shooting out of the two stand pipes, (which feed to the same drain line in the floor of my laundry room) geyser-like.
Is this normal? Do any of you find you can drain two washers at once, or am I asking too much of my plumbing?
I'm sure the drain pipes aren't clogging and I'm not hearing 'glug-glug-glug' from the vented floor drain or anything like that.
I've gotten pretty good at timing the two washers to avoid floods, but I was just wondering if this is a common problem when using more than one washer at the same time.
