Question re my WP Duet washer (that free one I got)
petek
May 28, 2009
11,842
Ontari ari ari O
It's the free one I got months back off the neighbors curb.. about 11 years old,  made in Germany.. Couldn't find my origin post.. Anyways I have a question to anyone who has one.. Mark?
I few times I've noticed that using the regular cycle which is 40 minutes total that the machine keeps adding water occasionally during the washing portion which is 10 minutes.. In fact just the other day with a smallish to medium sized load on the 10th minute it added about , guessing, 1/2 to 1 gallon of water,, and as soon as the water shut off within 20 seconds it started to drain and go into the spin cycle heading to the rinse..  Why would it be adding water so late in the wash cycle?   I've also noticed a few times that some stains were left on clothing that should have been removed.. I still think the machine isn't adding enough water and it's just tumbling around wet clothes..
Hey - yes
mine does the same thing - 40 min total cycle, wash cycle pretty short and at the end adds more water to cool down, then immediately drain. I hardly EVER use this cycle. The same thing happens in the sanitary cycle. It adds more water at the very end, then drains.
my Neptunes do that.....but I think its more of the Stain cleaning abilities of a FL machine.....
first, enough water to saturate clothing and distribute detergent....almost a pre-treatment of a highly concentrated detergent lather, about 2 times through the wash part, at 5 minute intervals, it adds a bit more water, which starts to break the dirt/suds from the clothing and transfer it to the water to be held in suspension until drain portion flushes it away, also taking a greater part of the suds with it....
as some machines will add bleach during the last minutes of wash, this one adds it during the first rinse, after a short spin interval, using cold water...
may seem odd to view this, but is very effective at stain removal...
The Duet only uses a small amount of water, even less than a Neptune IIRC. When you choose warm as the temperature, the water in the machine will be near cold, because the water comes into a cold machine. You may get away with using hot water for a warm wash, it also depends on to what temperature your water heater is set.
