This Is A DD WP Compact Washer
Hi Matt, The capacity of these washers is about 5-6 pounds of cotton clothing max. The tub is 1.5 CF.
The suspension tri-pod that can break is the frame that holds the transmission, clutch and also supports the tubs etc. To replace it you have to take the washer entirely apart, but its not that bad a job but takes about an hour even for me. Good news is the part is still available, bad news the part costs more than you are paying for the washer.
Keep in mind the TPs while we saw a lot of them break usually only broke of machines that got a lot of hard use, most owners never had that problem, and other than that problem these are really rugged little machines.
John L.
