Questions about Maytag wringer machine
chad_hauris
Jan 25, 2006
94
I saw a Maytag wringer machine in an antique shop today I was thinking of getting and had some questions on it maybe you can answer. It is probably a 50's or 60's model with a round tub and detachable lid. The wringer release bar is turquiose color. My Grandma has one and still uses it but I haven't seen how one
works in many years.
1. Are the wringer rollers supposed to be apart when the machine is off? These rollers are pressed together.
2. The wringer release bar does not appear to move well...could something be jammed?
3. What does the round button on the bottom front do? Is this the power switch?
I have years of experience in electronic repair so I know I can take on fixing it but have hardly any experience with wringer washing machines, need some advice from an expert.
Don't know any of the other answers,but I can tell you the answer to #1 My grandmother had a wringer washer,and she always tripped the roller release after finishing her wash. She said it would make flat spots on the rollers if the pressure was left on while the machine was not in use.
BTW: I can recall a few extra rollers in storage in the garage. Some were black instead of white. Grandma said those were all that were available during the war. She disliked those as they left black marks on the bed sheets,and other whites.
The motor was on when the washer was plugged in to an outlet. The belly button knob was pulled out quickly and completely to engage the agitation gears. The pump was activated by a lever on the side that pulled the pump drive wheel against the motor. If it had a metal goose neck on the end of the drain hose, it had a pump. If no goose neck, it was a gravity drain or has a pump that maybe stopped working or the part was removed and lost. I love the sound they make when agitating.
Get that wringer!!
Greetings;
The release bar on the wringer really doesn't move a great deal. On top of the wringer, you'll notice a lever, twist that leaver to engage the tension on the rollers.
After done w/ the wringer, press the blue release bar.
What I do w/ mine after use is, release the tension, then I lift the top portion of the wringer then twist the tension lever again w/ the rollers seperated, hence, no flat spots:>
Usually I just put my hand between the rollers, and lift the top portion of wringer, then twist the tension lever.
Wringers are a BLAST to use!!! Wouldn't part with mine ! !
Hope this helps...lemme know if ya need further info.
You go . . fetch that machine...you'll not be sorry :>
Al
I have a 1954 model "N" round tub. The release bar just moves slightly. Try turning the bar on top of the wringer clockwise. If it "locks back in place then the release is working. I say go for it. As maytagluver said...they are a blast to use, not to mention they clean very well.
