i would appreciate any info you guys can give me on the proper maintenance of my new 1965 jet action rollermatic washer. i want to start using it on a semi regular basis but am paranoid i will do it harm unless i lubricate it first. it is 44 years old and even though everything seems fine and it looks like it has had a very good life i want to take every precaution. here goes.
i wanted to lubricate all bearings in the part of the transmission i can get to. will it hurt machine to lay it on it's side or flip it upside down (removing top ofcourse)? will i put any undue stress on any part of the tub drive system or tub bearings or water seal?
i know i can't get any oil on the rollers but i feel i should lubricate the bearings associated with them. what oil should i use, 3 in 1 oil or 10w30 or any special oil?
what weight oil do i lubricate motor bearings with. i always use 3 in 1 oil on my hobart motors?
i plan on making it a gravity drain and am going to bypass the pump, the logic being that all water will flow out of machine keeping it dry between uses. any feedback on this?
i did start researching old "rollermatic" posts on this site last nite and found some good stuff! you guys are really great! that one post about the history of the rollermatic was very interesting and informative!
the inner tub has one small chip in it, i was gonna use enamol paint on it, anything better?
if i did happen to get oil on a roller is alcohol the best to use to clean it off?
how often should i lubricate it's bearing points?
is there any way to get lubrication to the main tub bearing without a major dissasembly of the tub?
that's enough for now, again this site is wonderful for sharing info on our treasured appliances and i would greatly appreciate any feedback you have. i can see there are a lot of "rollermatic" guys out there!
up until now i have only dealt with hobart issues!
thanks a lot!!!!
pete
thanks a lot!!!!
pete
