Questions regarding Maytag LA712 refurb (series 04)
In the diagram, it looks like the agitator for the orbital transmission has additional small fins. I would think the orbital agitator would be rougher on the clothes than using the pitman transmission agitator?
What those diagrams aren't showing is that the later agitator with the "shark fins" is smaller in diameter at the base.
So for an equivalent amount of rotation, the outer edge of the fins moves a smaller distance on the newer agitator. It also, by being smaller, provides more free space for the clothes at the bottom to move around in. The two of those combine to make it more gentile on clothes - countering some of the effects of the more rapid short-stroke agitation of the newer transmission.
Ok sounds good to me. I'll continue rebuilding the pitman and before picking up an orbital, I need to locate an orbital agitator. It looks like there's 2 orbital agitator models? And if I can find an orbital agitator, hopefully it'll come with the filter housing and fabric softener thing. I found a picture of an agitator but it looks different than in the diagram
My LA511 from 1984 does not have that last agitator picture. I dont remember or care what transmission it has but it is an old school Maytag from Newton IA and sounds the same as my sisters 1963 Maytag did. Mine fills to the top, washes a big load fine and cost me a $28 part in all those years, thanks to AW members. I will never get rid of my Maytag washer and dryer as the only thing a new Maytag has in common with mine is the logo.
I can't find Maytag washers starting with LTA but I found several starting with LAT.
The first pic agitator has a notch on the bottom four small fins, part number WP22004042.
The second pic agitator doesn't have a notch on the bottom four small fins, part number W11550891.
Either one will work?
Part Number for Load Sensor Agitator/Dispenser
The correct part number for the load sensor agitator base assembly that you are seeking is 22001821. The fabric dispenser housing is 22001805. The fabric dispenser cup is 22001806. The agitator locking screw is 22001819.
Several are available on eBay, although not cheap.
Merry Christmas everyone!
It seems the agitator is available new but the fabric dispenser housing and the fabric dispenser cup isn't available new.
