Radarange chromey
I had that same model in my first apartment.
I didn't know much about working on appliances then, so I tossed it when the door stuck closed. I spent 3 days trying to get it open and finally gave up. Never did figure out what caused that.
I probably would have kept it around longer to fool with, but there was a plate of leftovers trapped in it slowly spoiling, lol.
Kevin - I had the same thing happen on a different model that worked but didn't heat. Different model, same problem - I got the door open - had to dis-assemble it. It was a spring tension issue - too bad you had food in there.
