Lastly, here is the chart detailing cycle action, length, and amount of water used. As you can see, the rinse-only cycle doesn't begin until the timer advances through the pre-wash and rinse cycles, and uses the main wash cycle. This is why I advance the timer dial manually to the main wash when I am using it for rinse/hold, otherwise incoming water wouldn't be very hot. I think it's interesting that only the "Heavy" and "Sani-" steam cycles provide a rinse between pre-wash and main wash. I don't know what the logic was behind bypassing that rinse for "Full" steam and "Regular Wash" cycles. Surprisingly, this machine doesn't use all that much more water than the Motley Maytag it replaced.
I'm hoping to post a decent shot of the BobLoad I processed recently, but may need to tweak it a bit since it was taken by phone.
