westinghouse no turn speed broil
Pete my 1965 WH self-cleaning range in my basement has the no turn SB feature. When you used it you placed the bottom of the broiler pan on the 2nd shelf below the food being cooked so there really wasn't much mess to clean up. My range also has the motorized stirrer on the RF 8" element. This range also has the temperature controlled 6" elements on the left. But best of all the oven is self-cleaning including the porcelain drip bowls in just over 1 hour. WH had the fastest and most energy efficient SC oven clean cycle, and easiest to use just latch the door and select clean on the selector switch, no confusing clock to set.
