Ranges
Upper end ranges.....
Well they were of course one of the most known range brand of that time....
I don't recall I've ever heard about Gasfire being sold/advertised as a superior quality (upper-end) appliance, rather the advertising was pretty anonymous and almost non-existent.....
Is still a brand today, today Gasfire brand got bypassed alot, it is not so known today like before, of course not as Nardi which is probably the most known brand or Candy, Rex, Zanussi, Zoppas which are famous europe and worldwide also.....
My experience about Hertz is different: On one side there was a Norge fridge that my parents bought in the middle 50's and my mother sold in working condition after 1990. That was a wonderful and rather biggish fridge that never gave any problem and worked with a transformer for 220 to 110 volts, since here we have 220 volts 50 Hz like almost the rest of the world. BUT my (then) girlfriend brought from the USA a radio-clock that never worked here and we knew it was because of the different rate in Hz. And years later in the 90's (to be exact) we used to live by the Brazilian border in norther Uruguay and I went to a shop to buy a TL washing machine, with electronic controls and the attendant told me: if you're going to use it in Uruguay it won't work because of the Hz although Brazil in the southern area is 220V.So I didn't buy it and instead I bought and Italian Ariston FL that worked for some 18 years. That's my two cents. Gus
Gus.... I think it's different for a simple reason.....
That is simple Gus, I forgot to metion it but of course alarm radio clock and elettronically stuff like LCD, TV will not work with a different hertz, that is obvious, they will burn out or go crazy.
That is clearly warned in all the packages of converters that they're not suitable to be used for electronaical stuff like that, some even states they're not good for writing machines and calculators.
But for mechanical clocks and most motors as long for heating elements I believe there is no problem, my flip alarm clock goes strong.
about your efrigerator, I believe compressors at least newer would suffer hertz changes at least I've read so that they're delicate to that, infact in many step-up down converters is stated that are not okay to be used on refrigerators along with LCD and things mentioned before....
Better so, it means your refrigerator was one of the ones having a compressor that can support it.
Anyway electronical stuff suffer changes of herrtz not electromechanical stuff
Freddy,
Your experience with the flip clock is interesting. I thought these also had synchronous motors.  Unless yours is a kind of self-winding clock with flip dials (I've never seen that). Those I have seen mostly have Copal or Copal II motors.
Phil
I went to take a look at my alarm clock as I wanted to understand or read something....I noticed it does have a switch under that you have to turn with a screwdriver for the cycles, 50 and 60.
Never noticed it before, probaly it was setted so from my mother when I was a kid and never noticed it.
Anyway you're right, if it is true that electromechanical clocks runs thanks to cycles so a 60hz clock will not work with 50hz!
I just googled that synchronos motor and read about it. So it works with the cycles!
I did not know that!
You never stops to learn!
Blows my mind
...that stoves and many appliances from the 50's and 60's were not only full of details in function but over-the-top design and appeal. As someone said above, today's appliances are generally boring. If they have glitz and color, they won't be around like the 50's and 60's appliances are today..52-62 years later. Great thread. I wish I had something to show off, but I did find something really interesting...see link.
http://atlanta.craigslist.org/atl/atq/3287398991.html
Phil....
This discussion about the clocks made me so curious that I wanted to understand more of my clock and generally about electric clocks and how they works and learned alot of things I ignored, thanks!
I spoke with my sister yesterday of it about the alarm clock, and she does remember that granma gave it to us to bring to Italy because she said it was not working for her and had a problem of electricity, I believe that she knew of it by an electrician I bet she did not even know what cycles were, not sure what was the exact origin of that clock , she probably bought it used.....
I did forget about this story, I just remember I liked it so much with all the lights etc and was so happy to have it and my mom had to buy a new bigger luggage to fit it into...
It does have an hidden switch to twist with a screwdriver stating 50 and 60 on the 2 sides under the rear panel on the right side....
I believe it's the cycle switch and now it is pointed on 50, label tell 115/100 volts 60 cycle (actually 60 cy) a corner is cut so maybe it stated 50 cycle also, of course it's so....
I think it does have a kinda brake or mechanism inside to make it work right with both cycles and speed also....just guessing, or a thing converting hertz, not sure if that is that simple though....you look more expert than me.....
I'm not into clocks as you can understand, my father is more being a jeweler, I gotta ask this to him....
The clock states:
Made in Hong Kong, no date available.
Warnings are printed in english and japanese/chinese, but who can tell exactly? LOL
I believe it is from late 70s from the style.....
I also googled the matter and looks common to find american people with clocks running slower in 50hz countries, so another thing confirming you were right!
I never noticed my appliances works slower though, elements does not in my experience and nor motors runs slower significantly.
My mixer mix as it should blender also, fryer and steam irons all works like a charm and lamps too, so anyway what you could meet with an electric stove is the problem of the clock only I believe...
Anyway I'm glad I learned a new thing thanks of you Phil, that is good to learn of it that a 60 cycle clock will not work with 50, and this is good for many reasons apart personal culture...and specifically because I was watching one of those VTG electric coffee makers with built in clocks to give to my sister for Christmas!
Thank you for making me realize that.
I know this is an OLD thread...but since we like old things.
I have inherited this little beauty in a fixer upper we recently purchased. It is in the "summer" kitchen of the home, not the main kitchen. I am not familiar with microwave ranges and would just like some general information about it if any one has any. I don't have access to the serial number information at this time, but here are a few pics...
