maytagneptune
I went to the scrap yard today and saw a Brand new LG WM3900HW. It was mostly destroyed but I wanted a few parts. The spider arm was broken. I pulled the tub and removed the bolts but the tub wouldn't split for me to remove the drum for a firepit. So now were down another manufacturer with front loads. Only one left is Speed Queen. I hope they don't do this scam next. I knew this tub is sealed/welded because I put all my might on it and it will not split.
This is the problem.
Tub halves are Ultrasonically welded together (Can't change Bearings/seal/spider)
You will have to purchase a new tub assembly ($$-$$$$!)
DO NOT BUY ANY LG FRONT LOAD WASHER 2018-NOW. All Junk. LG is now disposable like everyone else. LG stands for Largely Garbage at this point. They need to make the "TROMM" Models again. I can easily repair those. My Neighbors have a 2016 LG WM3670HV and I can split the tub on that one. what is the point of putting bolts on it if the tub is glued/welded. Screw All front loads except the speed queens. I now hate Modern LG appliances. The top load is also exploding again!
