Refurbishing a 1986 Filter Flo V-18
stuftrock1
Aug 21, 2019
184
Kentucky
A few days ago I bought my first washer, a 1986 GE Filter Flo model WWA8320GALWH. It’s in alright condition, but pretty dirty. I’m gonna begin the long tedious process of refurbishing it. I’ve never done anything like this before so I have zero experience, so I apologize for any dumb things I say, do, or ask.
Here are a couple pictures of it before I started doing anything.
The agitator was stuck on there pretty firmly but after dumping too much WD-40 on it and pulling with more muscle than I could muster it finally came up.
When I got it, I made the mistake of transporting it on its back and the boot separated from the tub, so to fix it I have to remove the inner tub. However, the agitator bearing, the black plastic cap overtop the bolts is REALLY stuck on there. I’ve had WD-40 sitting on it for over an hour and it still won’t budge. On top of that, the plastic is pretty brittle. Any suggestions?
first things first....
picture number 4 and 5.....your filter flo hoses are on backwards....reverse them so the filter flow works during agitation....
as for the lower plastic bearing, there is a little tab on top you have to push in order for that to lift off....
the bolts holding the tub must use a 12 point socket.....
this of course is in hindsight....but you should have secured the suspension before transporting.....i have never had one of those boots pop off from laying a machine down, but it does happen....
but here is an idea for next time.....
I know there’s a tab on the plastic cap. Even then, it’s still completely solid. Like, fused onto something underneath solid.
That transportation idea though is actually brilliant! I’ll be sure to keep that in mind.
And how in the world did someone manage to put the recirculation tubes on backwards??
UPDATE: I finally got the cap off. There was so much yuck underneath that it had actually fused with the agitator shaft. So I got that and the inner tub out, and that inner tub was a lot heavier than I was expecting.
searching the archives will give you some insight that some of us have added little tricks of making the fill flume spray on the clothing...bypassing the lid switch...taking the restrictor out of the inlet valve...
Machine looks good
That machine is in very good condition. Review some of my threads and you’ll see how much worse it could be. I tend to go with the motto “if it ain’t broke, don’t fix it.” Check for rust and POR15 it. I always replace the big rubber gasket on the outer tub with a new one so I get a good seal when I close the top. Beware of new boots though some aftermarket versions don’t work and are not pliable and will dislodge or leak. Your old boot may be just fine and need to be cleaned and more securely installed.
Thanks! My boot feels very dry rotted and stuff so I’ll be sure to snag that one on eBay. I don’t think I need a new pump though. Mines a little yellowed and dirty but appears to be in overall good shape. Thankfully tub gaskets and splash guards are still available because I definitely need replacements. I would also like to replace the bleach dispenser too because is is extremely brittle and yellowed. The surface is also completely covered in micro fractures and chips.
Thanks for the help guys!
That’s a great machine!
And as you will find, these are very user friendly and easy to repair. I agree with Jon- clean that outer tub really good. Scrape the rust spots with a wire brush to see if you get any holes. If you do, use some plumbers putty to fill them and let it harden- works great! The get some POR 15 and do the whole inside of the outer tub. Rust is the worst enemy of a good filter Flo! Once that is dry, then install your new boot. If you should need new clamps, they are also still available. I’ve restored several of these machines. I’m working on one right now actually, from that same model year as yours!
All of these extra steps will ensure your machine runs like new for many years! You will love this machine! Good luck and have fun with it! You’re in the right place if you should need any help!
Happy washing!!!
Ok so I apologize for the long delay. I’m in college so I don’t have a lot of available time to put towards this. But fall break finally came and went and I was finally able to finish this.
The condition of the outer tub after cleaning it was absolutely fantastic. Very little rust and the original paint was fully intact and smooth as a baby’s bottom.
Got the inner tub cleaned up and put back on. The plastic bits like the filter spout, bleach dispenser, and clothes retaining rink have yellowed significantly and are very brittle. They were also extremely difficult to clean and I couldn’t get all the dirt off. After I got the inner tub in, I put the rest back together with the new splash guard and upper tub gasket.
And now it’s finished! It works and cleans great! It is a bit louder than usual and I think the motor needs some fresh oil. I also noticed that my 2 speed clutch has lost its 2 speed ability as it doesn’t agitate any slower on gentle. However, I have absolutely no idea how this clutch works, let alone know how to repair it. So hopefully I’ll never have to wash any delicate items then.
