Relisted: GE P7 Americana double oven range - free (Pflugerville)
ovrphil
Aug 29, 2012
7,393
N.Atlanta / Georgia
Still available and reposted :
" GE P7 Americana, electric, standalone, double self-cleaning oven, model JHP56G061AD.
Vintage late 1960's or early 1970's in almond.
Except for the clock/timer this oven still works well and was still used until recently. This oven is a beast and will easily handle both ovens and the stove top simultaneously.
The range in the picture is avocado color, mine is almond, contact me if you would like to see actual pictures. " [this post was last edited: 7/13/2014-10:11]
Phil:
Actually, I think the "seller" is a little off-base in his or her assertion that their range is just like the Avocado one shown.
By 1971, GE had re-engineered the cooktop from the one shown here. The new cooktop had no trim interchangeable with the old one, with the possible exception of burner rings.
Since Almond didn't hit the market until late '76 for the 1977 model year, an Almond Americana should not have the same cooktop shown on the Avocado unit in the ad above.
The redesigned Americana cooktop is shown in the photo below; you can see that only the oven door is unchanged. [this post was last edited: 7/13/2014-20:51]
P.S.:
The Avocado one in the ad shot above DOES use the same cooktop my J757 does, so if anyone's parting a White one out, I'd be deliriously happy to hear about it!
I need a lot of cooktop trim, and I need the oven door outer skin and the oven door handle. I don't need the glass pack/shield assembly nor do I need the inner panel or insulation.
