toggleswitch
pics motor and pumps
Here is the motor assembly.
top to bottom:
1) Not clearly shown-- recirculating pump for filter flow "waterfall" and pan filter that sits over agitator. (black rubber hoses).
2) Drain pump (with white corrugated plastic hose).
3) There is a concrete block (not shown) opposite the motor for counter-balance.
3) "Flexible" drain pump drive. The pumps are mounted to the ourer tub which is fixed to the machine's cabinet. The motor however, moves with the inner tub and the transmission. The pump drive therfore need to be flexible!
4) motor- reversible- one direction agitats and recirulates water, the other drains and spins. Second speed IIRC is achieved by a "gear" in the transmission.
top to bottom:
