waternai
DISASSEMBLY:
There are two springs that hold the oven door shut. This is how I replaced the cable and reconnected the spring on the right side behind the panel. I couldn’t get the screws out to connect the cable to the wire hook on the left side, but as far as I know, it connects the same way once you’re in there. Please excuse any dust bunnies seen in the photos.
— Remove the burner grates and the stove cover in the right side.
— Pull the kick plate off the front of the range at the bottom. It is just held in place with two pinch clips.
— Behind the range, there are four screws holding the side panel on—two where the top section connects to the main body of the range and two below that connecting to the body of the range. They are about 10mm and take a flathead screwdriver. Remove the ones you can see holding the panel in place. No need to fully remove the bracket holding the range-back up on top of the stove.
— There is one screw holding the top lip of the side panel to the frame at the top of the stove. Remove that.
— There’s a little chrome trim piece on the side between the side panel and the top section of the range, the stove-back behind the burners. I was able to gently lift it out of the way, which is fine. Unfortunately, it got bumped and broken off on reassembly. Don’t do that part.
I didn’t see how to fully remove it, so just be careful. Upon reflection, it might be that that piece is accessible if you remove the stove back from the top of the stove. If you try it, let us know.
— Pull the back of the side panel away from the back of the range to clear the panel’s lip from the back of the range and the top edge from under the stove-back, then slide the whole panel forward towards the front of the stove. It has a little pinch-bracket holding it in place in front, but the only screws are those in the back and the one on top. Give it a firm shove.
— Gently pull the insulation back from the lower corner at the front edge of the stove.
— Remove the screw holding the metal plates in the corner that keeps the cable and pulley from tangling in the insulation.
— The larger of the two plate simply lifts out of the way. That’s the only one you need to remove.
(Continued in next reply.)
