Restoring the 1959 Lady Kenmore.......
Jimmy -
Its a shame that you had all that trouble with the pumps. The 3-port pump is useful only in machines made from 1976 forward, which have either a waterfall manual filter or a non-recirculating filter under the basket (late production models after 1982 or so).
The three port with the boxy chamber as shown on the left in your picture is not capable of recirculating water directionally through the pump as the old 2-port is. Water flows through the inlet in only one direction and the recirculation is accomblished from the tiny third port, whereas in the two port water flow reverses direction based on the position of the shift lever and is always flowing in one side and out the other. All the shift lever does in the three port is open or close the back port for draining.
The three port you show pumps massive amounts of water per time as compared to the older pumps. Whoever advised you to use it on your beautiful machine was mistaken - that pump design wasn't "born" until your machine was 17 years old.
If in the future you have any issues with NOS pumps leaking, I have had some success with putting hot water through them - a load or two to make the parts warm up and expand has usually made a new pump seal itself again.
What fantastic shape the outer tub is in. That is GREAT. I think your decision not to pull it was smart - those rusty centerposts can often cause the tub lip to crack when pulling the tub, then it is much harder to seal.
I hope you enjoy the machine for many years. Great job!
Gordon
Another interesting tidbit about those pumps....
The majority of Whirlpool/Kenmore belt drive machines in the 80s were made to use the three port pump (WP's part number was 285317) though a few models used the old two and four port pumps.
One would expect that of the belt drive parts still supported by WP, it would be those still in most demand. Logic would then have it that whatever was used last and in most volume would be most in demand today.
Well, the three port 285317 is not available now from Whirlpool, yet the older two and four port pumps are (350365 and 350367). They are made in Brazil for/by Brastemp and exported to the U.S. Apparently Brastemp never used the "new" three port design. The cool part is they're made of bright blue plastic and more closely resemble the original appearance of the plastic pumps from the late 60s.
The three port is offered by Supco now (taken over from Gemline) and is even offered by Sears when a 285317 is needed. I have not had much experience with their pumps - has anyone else?
Thanks for the info on the pumps. Its a case unless you work on these a lot and have first hand knowledge of their application (which the dealer apparently did not) when it seems like you are using the right part and it still wont work then often these things are considered "unfixable" and get relegated to the junk heap. For the sake of simplicity, I left out a lot of information dealing with the NOS pump I tried to use. It leaked from the upper pulley shaft. Upon disassembly and inspection the rubber shaft seal had completely compressed and cracked from age, even tho it had never been used. I tried another impeller/shaft/seal with no luck and gave up on it after several tries. The pump I finally used worked and worked very well......There seemed little logic to using an old pump when I had (more than one) new one in my parts inventory.....
Sounds like you have had a lot of experience on Kenmores.....Im sure you will agree they were a great design...Restoring this one got me back in the loop from the hundreds I had done in the past.
Thanks again for the info on the pump.....PS. I made sure I didnt tighten the 95405 belt too much to ruin the pump bearing!
Jimmy,
Thanks for posting the pics of the restoration.
I now have a visual to go with all the explaining that you have been telling me about the restoration.
Now all you have to do is kneel and pray to the God of Washer Leaks to keep that baby running trouble free for another 50 years.
Jim
whow man.....
this is one awesome report. and the photo's are great. Good job on this washer!
Though you had problems with it looking at the pictures, I though most of the parts, like the "self-cleaning" filter, etc., looked to be pretty well preserved. Congrats on sticking with it and restoring such an interesting machine. Thanks for all the pictures it sure is a help in the future when another one pops up.
