Unimatic experts, Last week I started the restoring of my Frigidaires Unimatic WO-65, but I've found the first issue that made me stop and ask for your help.
Trying to remove the pulsator, the pulsator nut that looks like a cone with legs was very easy to be removed using an ordinary wrench and some WD40 but right under it, i've found this (look the picture) and I couldn't understand exactly what's that tiny "C" ring.
I don't know if it's another nut that is screwed above the polsator or if it's part of the pulsator or if it's a clip.
Could you please tell me how to remove it?
By the way, I'm spraying WD40 on it several times a day to maybe help until i know if I should turn it (unscrew), turn the whole rubber ring or just push this ring to the side or maybe cut it and remake the screw.
