Resurrecting a 1964 Whirlpool Top Loading Dishwasher, Pristine, Except...........
mickeyd
Sep 23, 2009
5,448
Hamburg NY
Hello Folks, long time no create a thread.
It was going to be a great day, a new top load dish washing machine, a surprise sixtieth birthday party for a long-time companion and best friend, warmth and sunshine in the forecast. What could go wrong, (laughs). Seller John was wonderful, and the last thing he said to me was, "If it doesn’t work right, call me and I’ll refund the money.”
Once home, immediately to the sink and the quick-connect., plug in, power on, the flush and rush of its first fill in 60 years, and then……….Yikes, Wanda Sykes, there’s water streaming down the kitchen floor. These early TL DW’s have all the risky business—electrix and plumbing—in the back with an easy to open rear panel , 4 screws and a flip up from the bottom, and "Thar she blows!" ~ Moby Dick
Great relief to find that the hoses, both supply and discharge, were all leak free; just the fill hose fitting was loose, so I tightened it. YAY. Water back on, but still the leaky stream. WT Fudge? Undo the coupling to find a worn—dry brittle shrunken— black washer. I hope that’s all, and this new washer does the trick.
All set: reset and restart, here we go. The super fast whoosh and rush of the wash arms, the changes in sound as the water level rises, then GEE WHIZZZZ, that’s a long fill. The timer clicks ahead, but the water is still coming in. Good grief, the fill valve is compromat; it won’t shut off!
Other than that, the machine works perfectly, LOL, as long as you keep turning the water off at the tap after each fill. Hoping Al or John or Steve has a valve for sale. What a shame if this pristine nearly brand new machine can only operate like a wringer washer, ha ha ha—I know, my favorite thing, but really……
I was tweaking because of the party, and I did not think to take pix, but I will show how cool the early design is when I open it up to install a new valve. I promise.
The display pix will come throughout the evening, one at a time, photo essay style, with notes to Al, Glenn, and John. "You all come back now, heah, (hear)," Jethro Klampett of the "Beverly Hillbillies."
Al and John asked about the top rack and although I haven’t spoken to seller John yet, I think they might be right. You see that extra opening for the upper wash arm? I thought, well it must be adjustable but when I put the axle in the other holes on each end, the shaft that brings the water up is at an angle that makes the wash arm insecure ; thus, those holes are not for switching the wash arm—how silly of me to think that the washer arm would be adjustable. Hello…… Therefore, these extra holes must be for the absent rack.
One of the four screws attached to the flip up backend. . I’ll show you how cool it is in there next time.
The innards out. You know the thing is so unused that there’s a piece of tape on the lower rack that had the booklet attached or something.-
Whirlpool gold. With a little drizzle; it’s 65 here today, like a summer day, but then it’s gonna be 20 something tomorrow. Everybody’s crazy lol.
It’s just so striking and everybody thinks it’s a brand new dishwasher and wants one of those newfangled ones that open up from the top, chuckle chuckle.
top rack
I did a little investigating and I only had literature for a previous model, SMP-65. I assume the "M" and "P" designate model year. The M series had 4 different models, with the -85 being top of the line. The -85 was the only one of the 4 models with the "Dual Roll N Load" upper rack. The other 3, like the original Filter Stream model, had the half-rack, "for straight-down loading". I bet they used the same configuration for all models and just eliminated that step-up feature.
Model coding at the time is that the 2nd character indicates the year of market introduction.  M is 1965.  P is 1966.
The serial may be late 1966?  The translation document I have references serial coding beginning at 1970 forward.  The coding was arranged differently at an earlier time, not sure when it changed.  The serial on the tag doesn't match the newer method.  I expect Combo52 can translate it.
Email sent
Michael,  I just sent you a message to your email address listed here but it bounced....  I'm in Brazil and only have access to email here.  If you still have my email address,  please contact me.  I may be able to help with the water valve.
Fixing the inlet valve
Since the DW is so low use. You can take the inlet valve apart and soak the parts and cleaner like CLR and reassemble it see if it works in a worst case scenario you just need to replace the little valve diaphragm which are still readily available finding the complete exact valve for this dishwasher might be difficult
Friendly Conversation
Thanks, everyone. Appreciate your time. First to Paul and Greg. I was subjected to an identity theft attempt, and caught it before losing a dime, but my email has been shut down for months, and I had reached out to both of you months ago; sorry you could not get back to me. I will enter a new email when this post is complete.
John and Cimberlee, you overestimate my skill remembering perhaps the Frigidaire DW where I needed only to repair leaks and install a shark valve which surprisingly required no tools. I have not worked on a DW water valve before, and would love to learn. Direct me.
Paul that new valve would be great, and Greg, I have another TL DW from Big Al in which the timer also failed during the dry cycle. OUCH. Had to repair the big hub's tiny attaching wings with super glue.
Thanks Guy and Brian, black is always beautiful;'D and to Glenn for giving the nod to John being more learned, (smiles).
Steve, that page of doctrine is exciting; can't wait to enlarge and enjoy later with tea and cake.
