Check out these two blenders. One has the traditional looking feet that can be seen below the base, and the other has fairly flat rubber pads that are obscured behind a wavy skirt embellishment around the bottom (I know this because I just nabbed this model and intend to give it to our SIL to use on his new bar).
I've noticed that it's usually bases with special finishes like copper, metallic red, or brushed chrome that have the skirt. Is there any significance to the skirt other than a reason to charge more? The blenders seem identical otherwise.
