Re: to fltcoils
Being a gold crown, does it have the extra solenoid and pulley for an extra speed? I don't recall if that was just for the Jet cones or also for the
1-18s.
As far as I know none of the 1-18's ever had an extra solenoid. What it does have however is a two speed motor and a dial on the control panel for "Gentle Wash/Spin" and "Normal Wash/Spin" The Deep Action Agitator, Direct drive rollermatics were the ones to employ the solenoid that engaged a high speed spin roller, they were refered to as Rapid Dry Models, and had a max spin speed of 1010 rpm. The standard rollermatic was a 710 spin speed. I believe this is also true in the 1-18 "Jet Cone" model except that low speed 330 rpm and of course it is a belt-drive setup.
How is the sound adsorbtion egg crate foam working out?
This is working out very well, it should be noted for anyone wanting to do this that you should apply the sound absorbing material only to the lower portion of the front panel (below the seam in the metal) application in any other area can interfere with the tub moving about during spin and will create undesired vibration and noise with all the rest of the metal cabinet.
There is one jewel of a 1-18 out there in this color that Mark was telling me another club member has that is all push buttons, and a load of washing combinations. I think it is probably the only one of it's kind around. I think a picture of it exists somewhere here in the AW archives.
