vintagesearch
- Joined
- Nov 7, 2006
- Messages
- 554
good day members,
well after a few recent trips to the laundromat to help a few friends of mine ive realized the wascomat frontloaders use a staggering less amount of water! before the water lines would be unbelievable high even the washer would be fully filled with water. they removed all the toploaders after they were bought out by a new company and its the same washers however they have been reprogrammed as follows:
hot is really warm no longer hot as it had smoke coming out from it before
warm is cooler before smoke would come out a bit on the warm selection (previously)
cold is pure cold
and delicate uses cool water instead of the initial warm
the cycles usually do a prewash main wash and 3 rinses however after the prewash the washer partially drains and adds more water before it would do a full drain and spin and refill.
the rinse levels are far lower than they ever were and shorter and the final spin speed are even slower
the washers also have these plastic small boxes located on the top right hand corner hmmm. weird and they all smell horrible in the inside they never did....im very disappointed and i will find a new place to take my mattress padding to be
cleaned so much for washers that can clean.....
cold is pure cold
