Rhubarb Banana Bread
kevin313
Jun 29, 2010
1,259
Detroit, Michigan
It's rhubarb season here in Michigan, and we're always looking for new ways to us this tart vegetable. We found a great deal on ripe bananas at the market and decided to make banana bread and include rhubarb in the mix!
Inspiration has struck with this one.. The neighbors across the alley sold their house several months ago, someone bought it and is using it as a rental. The tenants and owners don't keep up with the rhubarb plants so I decided to help my self...
Over 8 lbs... Freezing it and vacuum packing it then will try this recipe.
Thanks all!
LOUIS - yes, you can freeze rhubarb and I think that's a great way to preserve it. When I get it home, I rinse it off, dry it, and then cut it into pieces about 1 inch long. Then I pack it up in freezer bags - about 4 cups per bag - and put it in the freezer. Because it is made up mostly of water (like celery) the freezing cellular structure of the rhubarb will be a bit broken from the freezing, so when you thaw it you will notice it is soft - and you'll need to drain in. But it is ready to use in pies, cobblers, breads, etc. and tastes great!
JOSHUA - good for you harvesting all that wonderful rhubarb! It will now go to good use ;-) It looks good and your freezer will be stocked!!
HANS - so far, I really love the Kelvinator! It's a bit of a plain-Jane model, but the burners all work well and the oven holds well and bakes evenly. I'm kind of a fan of those front knobs - no reaching over a hot stove!
I should amend my post. If your freezer has a fan in it, always moving cold air, you can cut the rhubarb up, put the pieces on a parchment-lined cookie sheet and place them in the freezer for a bit. It'll be like a blast chiller.
I've noticed when I do that, the rhubarb is easier to work with and doesn't shed as much water.
I had over 32 cups of rhubarb from that bowl :-)
I spread the pieces over three half-sheet pans, froze them, then put them all in a container and vac packed 4 cups at a time. (When I washed the pieces, I used a salad spinner to 'dry' them before spreading them out.)
Now I just need some ripe 'nanners.
