Roy had a huge fight with Beryl sometime after July 1956!
jetcone
May 2, 2001
7,678
Schenectady-Home of Calrods,Monitor Tops,Toroid Tr
It must have been some huge fight since Roy wasn't paying attention to his job at Bendix Home Appliances that next day in August 1956 when he missassembled Edna's machine!
His mistake and lack of focus was a real shocker for 54 years!
Hence the reason Edna went back to her wringer beside the Bendix and never used it again so I got a "NEW" machine 50 years later.
Jon,
Beautiful machine!
Wow! Were the motor wires wedged into the upper connection of the left front shock absorber? That wire is so flattened out! With so much movement I could see the plastic start to shred.
I think you should sue Bendix! I think you have a case.
I am also glad that you were not shocked any worse!
Fantastic machine!
I am happy for you that it is safe now!
Brent
My guess ...
... is a shocking spin cycle.
That solenoid looks more like the drain or spin actuator, rather than something that would be at the top of the machine. It's really hard to tell from the angle of the photo, but I think it's the spin solenoid because I think we're looking at the rear of the machine, which places the motor/transmission at the left.
I'm guessing the shocks only came during the spin cycle because that's when this solenoid would be engaged, allowing power into the wire that's rubbed through and is touching the chassis.
Am I close?
And what a beatiful machine!! It was our first washing machine when I was a lad, so I have very fond memories of it.
SHOCKING BENDIX
Jon did you have this washer properly grounded ? We can't afford to loose you there would be no else around to slap us into shape. But seriously its imperative to make sure these old machines are properly grounded at all times. Its OK to use the old original two wire cord if its in good shape and you want to leave the machine in its original unaltered condition, just be sure you use a separate ground wire of at least 14ga for washers and 12ga for 240 volt dryers.
Bingo
Nick got it, that is actually the drain solenoid ( which actuates during spin) it would become a shocking wash experience at drain and spin.
Nick I have the motor set out so you are looking at the back of the machine but the front of the motor set laying on the floor pan.
Yes Brent the lead was bolted between the motor frame and cabinet, I had looked under there several times BUT as you can see it was a BLACK lead which was squashed between a black support and the frame so it didn't show at all!
The actual break in the insulation is on the otherside of the wire lead but I counldn't flip it over and hold the camera at the same time, nice copper wire showing through and contacting the frame believe me!
John, thank you for the sentiment and good point I always add a 3 prong plug to my vintage automatic washers but you are still wasting electricity to ground until you fix the short and you could always touch the cabinet and be a better ground than the ground wire so I am glad I found this.
It was all by accident, the motor set needed work as the centrifugal switch was getting stuck as they do on DELCO motors so I discovered this SNAFU when I was removing the motor set.
Soon Edna's washer will be doing laundry like a sailor at sea again!
Hi Jon,
Drivematic is now extra concentrated, so you get the same number of washes from a 1kg box, as you used to get from 2kg.
This means I can send twice as much for the same price :) Let me know if you need any more.
Cheers
Nathan
