norfolksouthern
- Joined
- Apr 1, 2009
- Messages
- 544
Has anybody fixed surface rust inside an outer tub on a vintage washing machine? If so, what would be the preferred method? Would Rustoleum primer and paint do the trick? Fortunately, there is not perforation or leaks, and I would like to keep it that way if possible.
Also, I checked the internal valve of the pump, and it looks badly corroded. That seems like a contributing factor in the pump draining during agitation, when the valve should be closed off. I haven't ruled out the wig-wag just yet. Mine is set up so that the agitator shift lever closes the valve when ever it's in gear. That part seems to work.
Sorry for all the dumb questions, but I'm sort of new at this. This is probably going to teach me a lot more than I think I want to know! Thanks.
NorfolkSouthern
NorfolkSouthern
