fredriksam
This is about laundry rooms but can applies to other rooms like kitchen and stuff. In wet areas the washing machines and driers should be installed in a safe electric m,anner. I have two examples of safe versus not safe so i will go through four pictures. What is the best and worst you,ve seen. Pictures are welcome.
First picture of right installed machines. We see the electric box on the wall. Only downside with this one is that the washing machine and drier seems to be on the same outlet. That can cause problems if one of the machines blow the fuse. So separate for each machine is better.
