aquacycle
I had a Miele W562 for 10 years and it was a lovely machine. I couldn’t fault it at all. I upgraded to a W1 machine - a WCG120 XL.
BIG mistake.
It have very bizarre programming.
1. The express cycle with only 1 rinse was near useless. I don’t use it often but it’s a handy feature to have for freshening up a small load.
2. The cottons cycle was 2:44 for no fuzzy logic. If the machine sensed a smaller load, which it very rarely did, instead of adjusting the time properly like my old machine, it would default to the short option.
3. On cottons short, the rinsing was appalling. It would fill as the machine ramped down from spin but as soon as the water level was reached, it would pump out. The rinses lasted about 3 minutes. And it only did 2.
4. Minimum Iron was a much more reasonable cycle at 1:58 with 3 rinses BUT if the machine detected it had anything more than a full load in it, it would abort the cycle at the end of the main wash.
5. In the year and a half that I had it, I had Miele out to it 3 times. The first time because water was pooling on the door seal and running onto the floor when I opened the door, the second and third times were for excessive noise. See link below. It sounded like it was trying to vibrate its way into next door most of the time. And yes, the machine was level and the transit bolts were removed.
I sold both the washer and dryer and bought a Siemens set last April, which are both fabulous.
BIG mistake.
