Samsung Dryer Grinding noise (includes video)
Sounds like the motor
because it's that type of buzzing. Does the pitch or loudness change as the dryer heats up? It may only be a thin metal cabinet part rubbing against another, or the burner baffle, like my Whirlpool dryer does.
They have lightened them up so much to save raw material and cost.
Thank you for the reply. It goes away completely (100%) in about 15 minutes after starting a cycle. And the amount of clothes has zero effect, if I have an empty drum it still makes this noise at the start.
Does that change your answer or narrow down the issue?
No, doesn't chasnge my answer.
I've learned to not pay attention to intermittent noises from things.
If it isn't broke, don't fix it.
Once I took my car in for a noise, and two days later something else broke.
If the noise is trouble, it will get worse, and constant.
You can vacuum out the exhaust of lint, and inside the lint screen chamber though.
I do that every six months.
