Samsung with "Power Foam" Technology...What will they think of NEXT???
stainfighter
Apr 22, 2005
556
Columbia, SC
Just saw the commercial of child in tub with Mom giving the favorite stuffed animal a 'bath' in the new Samsung with "Power FOAM Technology". Unbelievable what manufacturers will come up with next...it is already bad enough how the average Joe and Jane add way too much detergent just to see suds in their laundry. The foam was above the mid-point on the door!?! I wonder if they have beefed up the pump to handle all of that...hmm
The foam is supposed to penetrate fabrics faster... who knows.
Panasonic uses a similar technology to dissolve detergent: the detergent is flushed in the tub and then the drum begins to spin slowly. There are videos on YouTube of this system. I think the suds it created died down within two minutes. I think the YouTube channel to look for is "ad1969it"
I saw the Samsung commercial Sunday
My first thought was, don't we buy HE detergent and watch the dosage to prevent this from happening?  I am with others, I hope they beefed up the pump and seals to handle this.  OR I wonder what the life expectancy is on this machine?  In any case I could do this in my Maytag, Just buy regular Tide.
I also wonder what rinsing is like?
OVER SUDSING WASHERS
Almost no washer durability problems are caused by using too much detergent. But the reverse is quite another matter, too little detergent causes the great majority of main seal failures in FL and TL washers which always leads to main bearing failure and usally machine replacement. Too little is also the leading cause of water pump failure, to say nothing of machines covered in mineral deposits, mold, mildew slime and just plain stinky.
Here is part of the Samsung  story:
The power of PowerFoam ™.
Samsung has a new way to get your clothes cleaner. It’s kinder to fabrics, giving them the deep clean they need while treating them with the care required to ensure they last longer. It’s a gentle way to power out tough dirt, and it’s called PowerFoam ™. Available exclusively on the Samsung WF520 washer, it’s a better way to wash, with higher performance and superior fabric care. PowerFoam™ evenly distributes detergent by creating a foaming/bubbling action, removing deeper stains faster than normal detergent alone; leaving clothes thoroughly rinsed and residue-free.
http://www.futureshop.ca/en-CA/research/samsung-520-laundry-pair-with-power-foam/rc8892.aspx
CR's conclusion is not surprising when you consider that all of these new "features" are little more than marketing gimmicks to get consumers to plunk down cash for that "new shiny thing". All these new things are fads and gimmicks to get your attention and money. I wish they would pay as much attention to improving the build quality versus marketing "features" that don't do anything to clean your clothes or improve the longevity of the machine.
Everything That's Old is New Again
Personally I prefer the Kelvinator <span style="font-size: 10.5pt; font-family: 'Calibri','sans-serif'; color: black;"><span style="font-size: medium;">Magic Minute Dirt Loosener</span>.</span>
I'm very skeptical that this would make even the slightest difference to the laundry performance.
The main thing you need in a front loader is plenty of water moving through the clothes i.e. good old-fashioned scooping technology tends to do the trick rather well. I'm not impressed with sprays and pumps. They seem like more components that are prone to failure.
A well designed drum, good tumbling patterns and a powerful motor are far more important than these gimmicks.
Also, you're generally best to dose the detergent (including liquid) via the drawer as it means that it's in solution right from the start of the wash. If you add detergent to the drum directly in a ball / tablet, it has to dissolve as the laundry's saturated, which is wasting valuable chemical / enzyme reaction time when the solution should be in contact with the laundry. This is particularly true where the machine is heavily loaded.
This power foam business sounds to me like the same kind of hype as "scrubbing bubbles."   I don't see how bubbles, suds or foam contribute anything to the actual cleaning process other than sound or look impressive.   Isn't it really the chemical/enzymatic action of detergent, dilution (water) and agitation (scrubbing, plunging, tumbling, etc) that do the real work?
