cfz2882
on one of the automotive forums i am on,there is discussion of a new scroll type compressor to replace original GM R4 piston type compressor used in a lot of 76-95 cars
robably made in china,these aftermarket compressors look very similar to original GM version.some users of this scroll design note AC performance at idle seems subpar compaired to original R4. Earlier R4 compressors were known to be craptastic,but possibly was improved later in its life these things generated a lot of aluminum dust that would mix in the oil and foul the shaft seal causing it to leak,oil slinging off the clutch and pulley.The large o-rings for the outer sleeve would leak in cold weather too once they were a few years old.
