fan-of-fans
Last weekend I found the aforementioned machine at an estate sale. I was happy to see it because I've always wanted one since I saw them in catalogs.
I liked the idea that it can be used as a steam cleaner or a wet/dry vac.
Or at least I thought it could. This one came with only the hoses, wands and carpet cleaning tool. I was so happy about finding it I didn't think of the fact there was no filter inside.
Downloaded the manual and apparently this takes a round filter that of course is NLA. Now I know later versions of this could be used with paper bags instead of a filter. But mine has no bag holder since it predates the bagged models. I suspect the previous owner never used this for anything than carpet cleaning so never bought the filter or dry vacuuming attachments or anything extra than the basic machine.
So my question is how do I convert to dry pickup without the filter?
I thought I had a great idea. This uses a somewhat odd hose size of 2-1/4". So I ordered a 2-1/2" to 2-1/4" hose adapter. I figured that since 2-1/2" is what most Shop Vac hose openings are then their bags are probably that size opening. And the rubber on the bag should be able to seal to the adapter and the adapter could serve as the bag mount.
But today I looked at bags both at Lowes and HD and I get the feeling the bag openings are not that big. I couldn't find anything giving the size of the opening. I should have measured the bag mount in my Shop Vac even though I never use it with bags.
So any ideas? I did see Shop Vac sells a cloth bag with elastic closure that fits over the motor cage maybe that could fit this in place of the big NLA filter. But I already spent $8 on a hose adapter that may not work... didn't want to make a similar mistake.
In the third photo you can see that water deflector that covers the hose opening. I think that would get in the way of a bag but I can remove it via two screws you see on either side on the outside of hose opening. Would make conversion from wet to dry cleaning more tedious though.
You can also see the motor. You think a cloth filter would fit over it instead. I even have cloth disc filters for my Shop Vac that might work.
Thanks for any help.
