Hi,
First post on this forum!
My wife and I purchased the Miele W1926 washer (and matching dryer T1526) shortly our marriage in 1998. The appliance set is probably the best purchase I ever made (with the fine exception of a wedding ring
. The Miele have been running almost flawlessly since and clean clothes exceptionally well.
Unfortunately this week the washer is showing an issue with a loud noise during the final spin @1200 rpm and damaged door seal in the form of powdered grey rubber.
So the rotating drum is rubbing against the seal...
I removed and cleaned the door seal. Close inspection shows only minor damage. The rubber itself seems in very good condition.
I also cleaned the lip of the inner drum because the rubber left a hard gritty residue that transformed the drum into a grinder. So the washer may work ok for a while.
Lifting and lowering the drum by hand and a jerking it front & back, I notice that there is no play in the movement. Rotating it makes no nasty noise. To me this indicates the bearings are in good condition.
OTOH, rotating the drum by hand the drum moves a excentrically by about 6 mm. This, I surmise, causes the drum lip to slightly pinch the door seal against the outer drum at high rpm.
That said, looking at various internet sites on Miele washers, it appears the excentric movement of the drum is caused by a damaged inner drum "spider" (that joins the drum and spindle).
I have two questions:
1) Do you think the issue is caused by the damaged spider?
2) Is the spider replaceable? I ask this second question because the attached parts diagram doesn't show the spider as a component, nor the spindle, leading me to conclude the spider, spindle and inner drum form an inseparable assembly (part #12).
Regards,
Michel
Regards,
Michel
