Selectric Afficionados
cadman
Sep 7, 2004
1,581
Cedar Falls, IA
I know we have some typewriter fans in the group that might appreciate this. Recently I finally closed the deal on an IBM 2741. This is a heavy-duty version of the Selectric outfitted for computer interface work. Fortunately, it was completely overhauled in 1994 and it doesn't seem to have seen much use since.
Part of the challenge has been figuring out the 55-pin non-standard connector, and in typical IBM fashion, there's error checking built-in that creates a lot of additional wiring, fortunately I'm 99% there.
Anyhow, one of the first things I noticed was a cracked and sagging carrier cord pulley. It seems these go bad on ALL Selectrics. The reason for this post, however, is that it appears new and improved replacements are now available. Mine arrived tonight and works great! I opted for the rebuilt assembly which appears to use a delron/aluminum slide pair that's a much better design than the original.
So, if you have a Selectric stashed away because of this ailment, break out your wallet and have a look at the link below! -Cory
http://www.typewriters.com/selectric-parts.html
I'm torn when it comes to Selectrics.
Do I want one of those small rounded early ones, or a later, larger correcting one?
I think if supplies were still available for the correcting models, that would be more practical these days, seeing as how I've become less disciplined and type faster when all it takes is a backspace to correct any mistakes in a Word document.
Still, I don't know what I'd use a typewriter for anymore.  I already have two manual portables that I never use.
The sound of a typewriter with keys going at a good clip sure does bring back memories, though.  It's not quite the same with a Selectric, but back in the old days, the people in the office who had to type up important documents and correspondence were the ones who had the Selectrics.
A lot of people learned how to program a computer using the IBM 2741. In the 60's & early 70's you'd find at least one in most IBM computer customers computer center. Even though they can be used with IBM's System/360 and System/370, I most closely associate them with System/360.
