SERVIS Supertwin 108 question
Supertwin
Do you mean the spin drain hose or the wash tub drain. If its the spinner drain then I doubt you would get a replacement rubber hose but any sort of generic drain hose, with the added benefit of a jubilee clip should be fine.
If it is the wash tub drain, Mike or Mathew might have one in their parts stash
Al
Hi Al, Sorry probably I didn't ask the question very well - I have found hoses for both the 110 and the 100 in a spares shop in Liverpool - I just wondered if either are common to the type used on the 108 as I would rather use a rubber one than a generic type if possible.
Thanks, JR
Hi JR
The hose for the 100 should fit. The 108 needs the tight bend on the outlet in the pump to exit the machine and the 100 hose has this. Here's a pic I nicked from a spares website of the 100 hose.
S
