Hi, its been a while since I've posted. I have 2 Miele w1918 set up in the basement on one set of laundry shutoff valves. I got brass "Y" connectors to do this, several years ago and it has worked great. Now I have a 3rd set, a Miele w1113, that I'd like to hook on. I would need to hook up onto this same setup, or get the plumber to plumb me a new shutoff valve further down the line.
Other issue is getting the intake hoses long enough if I use only one shutoff valve with "Y" connectors. I could connect 2 sets to get 10 or 11 feet which is about what I'd need.
3rd issue is discharging the water. I'm thinking of discharging 2 machines into a large laundry tub. Currently one discharges into the shower to the left of the setup, and the other discharges into the intake valve area, as seen in the photo.
So I'd like to know:
1) can 3 washers can work off one shutoff valve setup?
2) If 3 washers can be connected to one valve box, will it work to hook up 2 lengths of hoses to get the length I'll need to connect water to the machine, 10 or 11 feet away?
3) Can I discharge 2 washers into one large laundry tub, approximately 24x24" wide and 12" deep.
