laundry235
I was originally partial to the WXF660 until I realized that its normal cycle is like an hour and 10 minutes long. It does have some shorter cycles but I'm not sure if they would substitute well for me needing a normal cycle that is less than 50 minutes. I know the WXI860 has a quickintensewash feature which may work but I'm not really a fan of the recirculation otherwise. More specifically, I am wondering:
Can the WXF660's express cycle or another cycle replicate the WXI860's quickintensewash or would they not fill with water beyond the suggested capacity? Just wondering if it would automatically adjust water levels if I were to for instance load 12 lbs in the express cycle that is only recommended for 7.7 lbs.
Can powerwash/recirculation be turned off on the WXI860 and does it activate in all cycles including the rinse portions?
Towels cycle on the WXF660 seems to have a similar <50min wash time and similar parameters (RPM, rhythm, etc) to the normal cycle. Are there some secret parameters that cannot be controlled that make it rougher than normal cycle?
The reason I need the cycle to be under an hour is because it would necessarily be too rough on the clothes. It would therefore also make sense to question whether the express cycle is also more aggressive than advertised which would basically suit my needs. Many thanks.
