paulinroyton
Hi everyone. It’s been a long time since I have posted on here. I would like to share my views on Siemens Avantgarde. At the start of lockdown I decided to treat myself to a Siemens Avantgarde washing machine and heat pump tumble dryer, thinking I was buying a good quality German made appliances, sadly I was wrong.
Let’s start with the heat pump tumble dryer. The machine had a self cleaning condenser, which in theory is a good idea. However, once the dryer had finished the drying process it would leave a small amount of water in the bottom filters, as the filters on this was located at the bottom, the more I used the machine the more water was accumulated. I ended up buying a wet & dry vacuum to suck of the water. I decided to call an engineer as I wasn’t happy, the engineer came and said he would have to have a second opinion with a Senior engineer. So the Senior engineer was booked and came to look at my machine. The Senior engineer stayed for hours and came to the conclusion it was a design fault with this range of dryer and nothing could be done, I did express my opinion after paying a lot of money and having a design fault wasn’t good enough. After a long discussion with Siemens, they kindly refunded my money on the machine, which I most certainly took, lol. After paying nearly £1000 for a dryer I would of expected a good quality machine with no faults.
Anyway, let’s talk about the Siemens Avantgarde washing machine. A great machine, holds 10kg of laundry, however, the machine developed a fault with the door. A lovely engineer visited and to my horror said the machine is actually made in China under a license by Haier. I thought he was joking but he showed me the rating plate at the back of the machine that actually says, Made In China under license. There was a code, which the engineer confirmed it was made by Haier for Siemens. He did say this model was the only one, and Siemens no longer have links with Haier. I am quite annoyed in paying £1000 for a Chinese made machine. I was under the impression the expensive Siemens machine were German made. I can’t really fault the washer, it performs well, very quiet, and take so much laundry.
In future when I buy an expensive washing machine I will try my best to find where the machine is made,
