Siemens WG56B2A41 - a review
henene4
Feb 6, 2013
4,528
Heidenheim a.d. Brenz (Germany)
So, I had a very extensive wash day with this machine.
TL;DR:
For most people, this machine would be a great upper end choice.
I do think iDos would be worth the money. It is amazingly quiet up to the final spin. It washes very well and rinses just fine.
Cycles are on the longer side, but there are plenty of choices to get around that.
Now, the "nerd" review:
The quality of the machine feels great. I honestly can't say my VZug for 3 times the money felt much more high quality - biggest thing might be the drum, with this drum just plain feeling tinny compared to the VZug.
There are the small things the VZug just did better. One thing that amazed me about the VZug: The cover for the drain pump was shaped and sized in a way that in cofortably fit the typical amount of water you'd have to drain when cleaning the filter - no faffing with large towels, or containers, or such. They really went out of their way to make that possible, but it's just such a nice touch I'll miss it on any other machine, even though I don't think anybody else has that.
Now, wash cycles and performance:
Any cycle starts with load weighing. That appears to be mainly for iDos dosing. Above 60°C, there is no effect on cycle times. On Cottons with no load, it does cut some time. iDos dosing for the main wash would follow if selected.
Main wash time adaption however appears to be absorbency based. The washer extended wash times on several different loads - but I really ran many full loads. Heating does only start about 10-20min in.
Which brings me to the annoying part: The cycle times are just to long - but for full loads, VarioSpeed is just to short. What's really annoying: BSH recently launched 11kg models that limit their non-Eco Cottons cycle to 10kg, have a 70l drum aswell - and only take 3h for Cottons 40, while this takes 3:30h. They COULD be faster, they just aren't. And I just don't see any need for 2:30h as a default main wash time, especially since you have so many ways to extend it.
And cutting the time could be so easy. The washer can start heating right away, like a W1 would - it does so on VarioSpeed. It only runs the recirculation during specific parts of the sensing, so it's not like that would be stopping it. That would save something like 15min, with no drawback in performance.
It does do some nice things however. It appears that on normal Cottons cycles (and Cottons based additional cycles) it does several spin washers followed by heating once it got close to wash temp to ensure EVERYTHING is at temp with very large loads. It dosen't hesitate to take time to heat to temp as well. With a very full towels load, it took over 1h of heating to get to temp, and just added the time back on at the end of the main wash.
With large loads the spray gets divertedonto the door glass by the clothes diverter - that's just a design oversight.
Rinsing - for how bafflingly it behaves sometimes - is surprisingly good.
Now, the suds control feature does work well, but it has 2 major drawbacks. First off, it triggers WAY to easily. You can't really wash a large load without risking it triggering, regardless of dosing. But, it only allerted me when I wasn't using iDos, so I'll have to monitor that if that is a variable. But it sometimes said "Suds Control" in the app with no visible suds. If you already have the load data, just adapt the interim spins to do shorter, lower bursts.
And that routine can cost you 1 rinse in effect. If it does not succeede with draining, it does 3 fills with short tumble periods. Those do NOT saturate the load. It tumbles less than 10 times in that 8min or so routine. So it really is just suds killing. Cycles that should do 4 rinses though (like Cottons with +1 rinse, or Towels with +1 rinse) only do 3 proper rinses then - that suds kill routine is counted as a rinse and displayed as "Rinsing" in the app. But the rinsing actually done isn't much in that routine.
Laundry does smell much more like softner with this though compared to the VZug and it does use plenty of water, even without WaterPlus in my opinion.
Spinning is another thing.
It spins really well - on par with the VZug. And the interim spins are very intensive, which is a plus.
Balancing is odd. Most full loads balance in 2-3 trys - but even a partial load of relativley easy to balance items can take several minutes.
The suspension is relly soft, and the balancing routine is pretty slow to react - it already hit the cabinet once on the very first wash.
And it just isn't very quiet on spins above 1000rpm. The OOB accepeted is just to big for it to spin quietly every time. Even though this has an accelerometer, like most BSH-machines.
What is impressive is the pumps. They are near silent. Really eary almost.
Another thing: If suds control is triggered during the final spin (which - again - can happen with 0 suds present), it just skips the final spin? No notification indicating what happend, just the usual suds control message, but also only in the app?
And it does fluff up on some cycles, but not on most? Hygiene with Speed did do fluffing, but a 3:30h Cottons cycle does not? Why?
I am missing some cycles on here. There are plenty, and some like Super 30 are actually really well programmed.
I don't get powerSpeed 59min - haven't used it yet, but it only spins to 1400rpm and only goes to 40°. Hygiene only goes up to 60°C, but down to 30° or even below?!? The Towels cycle in the app is limited to 4kg, but takes north of 3h?
I don't have a 2-2:30h cycle. Even with a 10kg load, you'd have an hour to 90min for heating up to 60°C and washing, which is fine for most daily loads, even if the drum is pretty full. And you'd have time for a full Cottons rinse and spin sequence.
But then you have buttons like "Intensive Rinse" which adds 3 rinses - in theory you should be abled to have like 7 rinses on Hygiene then, right? Why? Especiall if having an Extra Rinse button that just toggles 3 extra rinses (like it works in the app) isn't that hard to design and serves the same purpose?
Steaming works pretty decent, but as with many, it incorporates the Easy Iron option. I washed 4 cotton dress shirts, and the shirts cycle with steam is limited to 400rpm. Those shirts were drip dry. 600rpm would be just fine, especially with steam added afterwards and the barely 90sec final spin.
So yeah.
This was a downgrade - but the washer isn't bad.
I just don't get how you have programming that is so obviously missing some polsih, but then have apparently completley different forks of cycle design for pretty darn similar machines.
The hardware on this machine is - just like it is with electric cars currently - typical german engineering. Really well designed in really hard to copy ways.
But the software is SO questionably thought out - just like with cars currently.
If you got any questions, just ask!
I’m pleased that you’re enjoying the Siemens. I agree with you they are a generally decent all rounder and I haven’t encountered a machine which rivals its spinning performance. The difference is about 10-15 mins in the dryer between towels spin in the Siemens and my M Touch W1.
I must say I barely use the longer cycles - I find that 3:30 is just too much overkill and nothing really needs it. It doesn’t even offer an energy advantage compared to variospeed, as the long cycles maintain temperature for a good length of time. I find that Cottons variospeed at 1:30 will just about wash anything (even full capacity loads) to perfection with more modest energy and water consumption (despite the manual stating otherwise). If you overload it will adapt the rinsing/spinning, and add bursts to the interim spin cycle for more absorbent loads. If you wash a half load on variospeed it will cut the cycle time down to around an hour to 1:10. Cottons vario with water/rinse+ is usually done in around 1:40-1:50 which I think is the perfect time for me. I tend to mainly use cottons vario for whites and towels, or more heavily soiled coloureds.
I also really like the mixed fabrics cycle, especially with how flexible and adaptable it is. I use this for most clothes and again this will adapt depending on the load - if you load a full load it will adapt the rinsing and also extend the final spin cycle. Combine with variospeed and you can have a small load done within 45 mins. I also add the less ironing option to get an “easy care” type cycle, as I find the standard ways care cycle inadequate - it’s either too long at 2:30 default or too short at 0:47 with variospeed.
I don’t find the suds detection a big problem with most loads, the only time when it is annoying is with large loads of fleece throws, or with the dogs beds. It could be more adaptive to avoid adding an extra rinse unnecessarily in those circumstances.
Powerspeed is pretty much a redundant cycle to me, and is just a “me too” cycle to compared against Miele QPW, LG Turbowash etc. The powerSpeed cycle as well as being limited in temperature also doesn’t spin between the rinses. I find in the same run time the mixed cycle is a more adaptable cycle and gives better results - especially as you can go up to 60°C, 1600, and does decent intermediate spins.
I’m still pleased with mine functionality wise and find it very flexible. I wish it had a cycle between 1:30 and 3:30 for cottons, and that it did an anti crease after the spin by default (although you can hack this by selecting the silent option in the app).
2.5 years down the line the suspension is wearing on ours - it’s quite loud on spinning especially with heavy loads, although (allegedly) is normal operation according to the Siemens engineers. I also find the iDos really difficult to clean - there is an inaccessible part of the dispenser box where the iDos dispenses into which attracts mould and is very difficult to access to clean. It would be great if you could manually dispense softener, but again that is my personal preference.
It would be interesting to see the programming on the new 11kg models, given the cycle times are shorter.
Jon
I’ve also had the WG56BTA2 model for nearly a year now, I bought it to upgrade my original 4D Siemens model with sensofresh mainly for programming upgrades, the IQ500 regularly limited its final spin
Overall it’s a decent machine, iDos is well designed where you can leave the drawer open while not in use and it won’t drip inside the cavity.
It is much quieter than my iQ500 was, even if iDos is a little louder than you’d expect.
Heating is almost always perfect bar 1/2 cycles and it will stop the timer to heat if needed, plus the pumps are basically silent.
However, I’ve found Bosch is pretty lazy with their programming, with a full load I’ve found mine rarely spends longer than 2min at full speed, somehow with MINI loads getting up to 5min at 1600/1700rpm. The time regularly extends for shorter cycles way past what they were estimated (even for the recommended load size). Water plus only adds water in like 2 cycles and most options, including that, reduces the wash action to gentle… why??
Pausing the cycle or adjusting anything during the cycle, it will also switch to gentle wash action (same as my previous model)
This model glitches WAY more than my old machine which didn’t glitch ones, many times I’ve had to switch it off at the wall. Sometimes you press on, it makes the on sound and animation and… nothing, need to start all over. Or you press on, and it makes the off noise instead and stays off 😂. My Bosch Serie 8 dryer is exactly the same or even worse.
They’ve adjusted the cotton programming with speed to only have to do one 4D spin after reaching temp before allowing it to drain if it has got to that stage, my old machine forced 3 4D spins on that cycle. They have only updated ONE cycle for updated balancing which means it’ll rebalance between bursts so cotton reduces the spin much less - mixed cycle? Nope still the same!
I find cotton speed is too short for a full load at 60 but switching it to mix will have it limit the final spin to say 1000 instead.
Washing anything bulky is a struggle wirh the low water levels, with only shoes being a proper bulky cycle, the Down cycle cancels the final spin as soon as it water locks
It does look nice overall but I think the iQ700 models previous with the TFT screen were much nicer and had a lot more options without needing to use the app.
Many stains cut out the use of the jet, which personally isn’t used enough to begin with, they should follow AEG with this now since the pump is already silent. Overall, I got this machine for £469 so I can’t complain too hard but I would never pay £1100 full price. In some ways I wish I had just kept my iQ500!
I’m tempted to rewire the pump myself so it runs constantly when a levels reached via a separate pressure switch
There seems to be many different programming differences across the same few models, even with identical model numbers. Some with the jet rinsing, some with not, some with distribution rinsing, etc. I know some also allow speed on the eco cycle and have Hygiene, whereas ours doesn’t (not that I’d use them anyway). Seems strange there are so many software versions across the board - when you think with the remote update capability they’d all theoretically be running the latest version.
Ours will do 3 or 4 spins with the jet in the wash on cottons variospeed and mixed. However it does do less than when we first got it, and also since it changed the load absorption technique on one of the updates it only uses the jet once before heating, and only once it’s heated into manually dispense detergent.
Water plus on ours will fill up the door between 5 to 10cm on the rinses a without water plus it will fill into the lip of the seal. It doesn’t add as much to the rinses on mixed but will still fill a little up the door for a larger load.
I’ve never had the spin limited on mixed fabrics or cottons, it will always go up to full speed. Our last IQ700 would sometimes limit to 1200. I’ve heard from another friend that it does on his though when using the mixed cycle. You also always get at least 4/5 mins on 1600 if not more on the cottons variospeed programme regardless of the load, and probably around 8-9 minutes if I’ve had the time, inclination and patience to use the long cycle. The only load it consistently refuses to spin is the doormats, which I just do in the W1 as despite being fussier in general to spin than the Siemens it always seems to be able to spin the doormat!
I’ve noticed the same with the gentle action tumbling being activated with any option changes or pausing - overall the results are still the same and everything is clean, it’s just a bit of a weird glitch and less fun to watch.
I agree with the TFT screen being a bit more user friendly in that you could access all the options on the machine. I appreciate the minimalist look of the IQ700 and the styling, but please Siemens bring back the TFT display 😊.
One thing I have forgot to mention is that I would probably use the longer cycle more, if the 60 cottons wash cut off more than 10 mins for a partial load. More often than not the other temperatures will take an hour or even more off for less than a full load, whereas the cottons 60 cycle just deleted a rinse. I’d be interested to see if the new cottons cycle on the 11kg machines which is 2:59 for all temperatures including 60, will adjust the time down.
Jon
This week, I used the delicates cycle.
While I would not trust that with Silks like it claims, it's not as terrible as some say, at least in my view.
I don't get why it tumbles THAT vigorously, and only 2 rinses by default without interim spins is a bit disappointing.
But it at least offers a pre-wash (though on the longe side - basically almost as long as the main wash) and with the rather short wash, over all, it's not too intensive. Water levels were acceptable.
Over all, for the few things I use that for, it's just fine.
powerSpeed 59 though is just beyond baffling to me - especially since Super 30 exists.
I somewhat understand the 3 rinses with no interim spins (no need to balance means it will do rinsing in the time alloted with all likelihood), but it clearly does not work well. It does not even fill particularly high.
But Super 30 - from the times I used it - is insisting on interim spins and in turn rinses way better.
And that cycle goes up to 40 aswell.
Main difference is the final spin which definitely is better on the 59min cycle - but why is that cycle limited to 1400rpm?
Makeing powerSpeed go up to 60C and 1600rpm would at least give it some right to exist - but like this, I'd just run Super 30 and respin.
Worst thing of all: I'm somewhat convinced that cycle is programmed entirely independently from other cycles. The app said NOTHING about what stage it was in.
And if that is the case, it's not even done well?!? It takes longer to start heating on the powerSpeed than Cottons with VarioSpeed does.
Why would such a cycle just spend the first 5min not heating - when other cycles do?
If you already open an entirely new page for such a cycle - just use that opportunity?
And if you don't want to do the work - take Super 30, extend the main wash time and adapt the final spin. That would perform WAY better.
Speed 30 - as rarely as I use true quick cycles anymore - has to be actually my favourite cycle so far.
It's basically a carbon copy of Mieles old Novotronic Mini cycle.
Wash up to temp, 2 rinses with interim spins, quick final spin.
Only up to 1200rpm and not full speed like the Miele would, but that's fine.
@henene4
I've had the same experience with my late 2024 Bosch: load sensing mainly appears to be through absorption. Time will change once heating starts - the only instance it dropped after the initial spin was when I started a cycle with no clothes.
Yes, times are on the long side, as with many washers today (save for the Swiss ones 😁). I have no need for those long cycle, as my clothes aren't that dirty, nor do my sorting habits utilize the capacity of the drum to the max. It's nice that the washer will add time when needed (even before starting to heat) and you can Intensive as well to lengthen shorter cycles.
I've only had the anti-suds kick in twice since owning the washer, so can't really comment on that.
Balancing would probably be better if the drum rotated both ways during balancing, honestly. Sometimes, the washer will sort of "give up" and do a burst even if the load is off-balance to remove some water. While that can look violent, it hasn't impacted the cabinet yet. 🤞🏻
Spinning. I feel like the software on mine calls for different spins from what I have seen on YouTube - or at least on the cycles I tend to use. It will speed up... but immediately slow down again. Although I can't recall all the cycles it does this on.
Another small complaint I have (besides the ones I DM'ed you about) is standing water in the fill hose that enters via the door boot. If you open the door, suction will cause some water to drip onto the door and then the floor. Don't know why there needs to be water in that hose. Maybe as a steam and sound barrier...
@lavamat_jon
I'd probably use Cottons + Speed and Mixed as my main cycles, too. I just can't bring myself to using mainly two cycles in a premium washer that offers 23 cycles. 😅
Thanks for mentioning the Less Ironing and Silent options. I have only tried it with Shirts, but limiting the final spin to 400 rpm was too low for drying them in the dryer afterwards and I never used the options again. I tried Less Ironing with Mix last week end and will try Silent (adding 25 minutes 😳) today.
Times in general are... interesting. Cotton Mini is 33 minutes but going above 60° will increase it to over 70 minutes. Going from 40° to 50 and above adds 20 minutes to Mix. Why?
Oh, there are absolutely different software versions out there. Water Plus on mine essentially does nothing but works properly on your Siemens. Every engineer got a shot at programming. 😅
@washerfinatic2
"Glad" to hear Water Plus only adds a little water on yours, too. I'm not expecting Miele Maximum Rinse Level type of rinses, but some extra water (more than a cup) would have been nice.
Haven't noticed options altering tumbling patterns... as I haven't paid attention. 😁 It will, however, pause tumbling momentarily if I (de-) select Water Plus during a cycle.
Yes, more jet action would be nice, especially in the rinses (although the paddles do shower the load nicely). I put a very short piece of plastic tube, if you will, into the jet outlet. Now, when it spinwashes, water actually hits the clothes instead of the back of the drum. W1 seems to have the same design oversight.
So, I tried Mix 40° with Silent Wash.
What was that?!
You'd imagine the 25 minutes the option added would be used to provide extra rinses to make up for a lack of interim spins. But no. It simply added 25 minutes to the wash, which now didn't include spinwashes or the use of the jet (save for the very beginning). Rinsing and spinning was normal, really. The only difference here was an added 8 minute fluffing tumble at the end. Weird.
Yes, I would have expected more changes. Oh, well...
And while I'm on the topic of expectation: how is it that there are no consumption values given in the app? Is that something only Miele do?
That's actually something I was wondering as well.
My VZug did, and obviously, Miele does. Some Samsungs do.
Why not these? I mean, these must do similar current and voltage monitoring like the Miele?
At least in the app they could give you a quick note.
A bit of an update.
You really do get used to this machine.
Now, I basically dry everything, so having high spin speeds in general is a plus.
I am somewhat dubious of the 1700rpm claims some people give to these machines from an engineer kind of standpoint.
And in general, I am mostly happy with a lot of things other people aren't.
I actually kinda like the delicates cycle - for what I need it to do. Which is usually stuff like more delicate underwear (I'm a gay man - I do have my share of stuff you wear close to your skin that needs to be treated like lingerie, yet you really wouldn't call lingerie).
And for that, Delicates Miniload Extra Rinse is superb.
I found myself using Towels for a lot of things - but not Towels or bedding.
The mainwash is really reasonable - something like 90min ish on normal and an hour ish on VarioSpeed if you exceed the ridiculous 4kg load limit. It does 3 rinses even with VarioSpeed. And you get that extra long final spin - great.
(One thing that urks me though: Why is there like no consistency between the washer and dryer? Why is Towels on the dryer for 6kg, but for 4kg on the washer?)
Wool however is straight up unusual. F-, for real.
There are a few things that make sense. It saturates the load fine with a few additional tumbles in the beginning, nice!
But not tumbling during heating makes no sense if you don't have the item fully submerged.
And stopping heating, not tumbling once, and draining straight after if you select 40C is again stupid.
And then the rinses - I think max is 1 tumble in the 2-3 rinses or something. Not per rinse - in total. No jet. Just fill, sit, drain.
I basically have to re-run the cycle on cold again every time.
One thing I didn't expect is that this really cleans better than the VZug in certain scenarios.
Mostly, my heavy soil boil wash with my kitchen towels and cleaning rags.
I set 90 Cottons, Soak, Intensive plus and almost all stains shift. I never expect 100% - but it does do better than the VZug on basically the same setting.
I did that load twice so far. The first time I thought the lower jet usage was due to the stain option - but the second time didn't really use the jet either.
A stain that uses temp hold does improve the result that little bit further.
So yeah - it's really a washing machine. It's just there. It does the job. Pretty well.
It's not terribly exciting - but it's fun.
