Simpson Fluid Drive A39
brisnat81
May 5, 2004
2,243
Brisbane Australia
Hi Guys,
I found this machine yesterday while curbside crawling, Its a two speed machine, with infinitely variable water temp, solid tub, infinitely variable water level (measured by pressure switch) 4 wash/spin speed combos.
I'm assuming that this is a Beam design of machine? Can anyone let me know if thats a correct assumption?
Drain tub fill, recirc port and Rinse Fill
Water enters the machine into the drain tub through the little inlet hose, until the pressure switch is satisfied.
If the heater is turned on, the machine then heats.
Once the water is at the right temp, the machine starts and pumps the water up through the hose on the left.
During Rinse the water is inlet from the hose on the right.
Wow Nathan, what a cool machine!!! Great find if you ask me!
This machine does appear to be a Beam design, judging by those two mega-solenoids and Fluid Drive. The pump looks like the same one used on solid-tub SQ machines as well.
