My dryer exhaust vent has a small cage to catch lint. I remove the little cage and clean it every two or three weeks. I've done this a hundred times without incident. When I cleaned it today, I accidentally pushed the back of the cage up a little too high and it was blocking the vent from opening.
I was watching a TiVo'd backlog of Family Guy episodes in my family room (next to laundry room) while the load was in the dryer (high heat, automatic cycle, laundry room door closed). It occured to me the load was taking a long time to dry. After awhile, I started to smell something 'hot'; I opened the door to the laundry room it was obviously coming from the dryer. I grabbed the timer dial and IT was hot. The top of the dryer was so hot I could hardly touch it. The console was quite warm, also. I opened the door and was greeted with a slight burning smell and a wave of very hot, humid air. There was no lint on the lint screen. The dryer was obviously not venting. I set the temp control to NO HEAT, started it up and ran out to check the exhaust vent. I discovered the and fixed the blockage, then let the dryer run for 20 minutes to cool everything down. Talk about a heart-pounder!
What's also scary is that, since I was using the automatic cycle, the dryer would keep running forever, as the moisture sensor was sensing wet clothing the whole time.
If you have a vent like mine, always be sure its cage is precisely in place!
