[COLOR=black; font-size: 12pt]<span style="font-family: Times New Roman;"> [/COLOR]</span>
[COLOR=black; font-size: 12pt]<span style="font-family: Times New Roman;">I too was very curious about how things worked when I was younger and have taken things apart to figure it out. As I remember most of the time I would put it back together too, LOL.[/COLOR]</span>
[COLOR=black; font-size: 12pt]<span style="font-family: Times New Roman;">I have solid mechanical ability, so working on a car or an appliance is generally not a problem. However I've found if I have never done a certain job or repair before, I am hesitant to do it w/o someone helping or at least giving direction.[/COLOR]</span>
[COLOR=black; font-size: 12pt]<span style="font-family: Times New Roman;">As for plumbing, electrical or other jobs around the house, plumbing is no problem. Installing copper pipes, no problem. I installed a water softener which required building a lot of plumbing (copper), valves, etc. I also added the copper supply and ABS drain lines for the 4 washing machines I have (connected) in the garage.[/COLOR]</span>
[COLOR=black; font-size: 12pt]<span style="font-family: Times New Roman;">Also, when we had the master bath remodeled, we told the guy (hired for the tile work, but somehow talked my ex into doing the whole project) the plumbing for the two new sinks had to be a certain way due to their locations and the "floating cabinet" to be hung on the wall. I came home from work and when I saw he had the new plumbing all jacked up, not the way it needed to be, I stopped him and sent him home for the day. I then went to Home Depot, bought everything I needed, removed everything he installed and re-did the supply and drain lines myself. It took quite a while and I only got 3.5 hour sleep that night, but at least I know it was done right.[/COLOR]</span>
[COLOR=black; font-size: 12pt]<span style="font-family: Times New Roman;">I'm also good with electrical in the house. Replacing switches and outlets, no problem. I even installed 17 recessed "can lights" throughout the house. I also removed the brand new, but O-M-G so cheap, less than $190, POS dishwasher and installed new Kitchenaid at the time.[/COLOR]</span>
[COLOR=black; font-size: 12pt]<span style="font-family: Times New Roman;">As for other projects, let me just say I'm good with "the meat" of the job, but not the fine details. Like when painting interior walls for example, give me the roller and I'll get the majority of the wall, but I much prefer leaving the "fine detail work" of cutting in the corners or trim to someone else. I guess I don't have the patience for it. I'm also OK with cutting lumber, pounding nails, etc. Big stuff in the yard, trimming trees, etc is fine, but the small stuff like pulling weeds most of the time, forget it.[/COLOR]</span>
[COLOR=black; font-size: 12pt]<span style="font-family: Times New Roman;">However I have found that as I get older, I’m also getting lazier. Either that or I need someone here to motivate me.[/COLOR]</span>
[COLOR=black; font-size: 12pt]<span style="font-family: Times New Roman;">Kevin[/COLOR]</span>
<span style="font-size: 12pt;"><span style="font-family: Calibri;"> </span></span>
